DS1302 Question
I am working with a DS1302 timekeeping chip and would like to setup the
backup power for this using a diode and capacitor.
The documents leave the choice of a diode and capacitor up to the user.
I have no idea what to use.
Could someone recommend, including part numbers if possible, a suitable
diode and capacitor combination?
I am interested in it holding power for at least a couple of days.
Thanks in advance.
Thanks in advance.
I'm trying to display the current time, using a DS1302, in hh:mm format to a
serial LCD. The display seems to work, but, I'm screwing up the math
somewhere on converting the time from the DS1302 raw time format to the
format I need. Below is the formula I'm using, basically, it's not
converting over 60 minutes (ie current time on the clock is 12:88, it's been
runnig for several hours.) What am I missing?
SEROUT LCD_SER, N9600, [noparse][[/noparse]DEC2 12 - (24 - (hrs10 * 10 + hrs01) // 12), ":",
DEC2 mins]
Thanks for the help,
Matt
Matt Georgy wrote:
>I know this is basic, but, I feel like a monkey doing a math problem...
>DEC2 mins]
>Matt
>from the same email address that you subscribed. Text in the Subject and Body
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
and it comes out correctly it is a form of BCD without the
letters
Sent: August 08, 2002 10:29 AM
Subject: [noparse][[/noparse]basicstamps] DS1302 Question
problem...
format to a
math
to the
not
12:88, it's been
12), ":",
DEC2 mins]
Matt
Subject and Body of the message will be ignored.
use 'HEX2 mins' instead of DEC.
88 is HEX 58 which is what you want.
Cheers
Col
problem...
format to a
math
the
it's been
12), ":",
> DEC2 mins]
> Matt
