scratch pad RAM question
hello,
I was wondering how i can have a variable in one probram bank be able
to be used in the other program banks (0-7) is there some special
instruction for this?
lets say the variable was called steve
steve var word
steve = 1234
how do i get all 8 banks of memory to recognise the variable steve?
pleas help...give example code if possible!
thanks
steve
steve var word
steve = 1234
thanks
steve
sznavor23@hotmail.com writes:
steve var word
steve = 1234
No and Yes. ·Since "No" is not the answer you want, let's get to "Yes."
If you have the same variable definitions in all eight banks, your variables
will remain intact. ·Since this is not usually practical (the "No" part from
above), you have to use the Scratchpad RAM to share variables.
You write data in the SPRAM with PUT. ·This works like WRITE, that is, it
writes a byte to the scratchpad. ·You can retrieve a byte from SPRAM with
GET. ·In your case, with a word-sized variable, you'll need two PUTs and two
GETs. ·Like this:
' Pgm 0
PUT 0,steve.LowByte
PUT 1,steve.HighByte
RUN 1
' Pgm 1
GET 0,steve.LowByte
GET 1,steve.HighByte
[/font]
What you say is true. However, one way to make sure this is OK is to quit
letting the BS2 assign variables. Do it yourself.
So if you say:
steve var w1
al var b0
Just make sure you understand that b0,b1 = w0; b2,b3 = w1, etc. etc.
Now if all the programs use the same it all works.
So I agree with Jon, No if you auto assign variables, yes if you do it
yourself.
Al Williams
AWC
* Spring break special: http://www.al-williams.com/awce
steve var word
steve = 1234
No and Yes. Since "No" is not the answer you want, let's get to "Yes."
will remain intact. Since this is not usually practical (the "No" part from
You write data in the SPRAM with PUT. This works like WRITE, that is, it
writes a byte to the scratchpad. You can retrieve a byte from SPRAM with
GET. In your case, with a word-sized variable, you'll need two PUTs and two
GETs. Like this:
' Pgm 0
PUT 0,steve.LowByte
RUN 1
' Pgm 1
GET 0,steve.LowByte
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
>steve var word
>steve = 1234
>thanks
>steve
Hi Steve,
Make it the first variable you define in each and every bank:
' this is program steve.bsx, bank 0
'{$Stamp bs2sx,steve1.bsx,steve2.bsx}
steve var word
steve=1234
run 1
' this is program steve1.bsx, bank 1
' {$stamp bs2sx}
steve var word
debug ?steve
run 2
' this is program steve2.bsx, bank 2
' {$stamp bs2sx}
steve var word
steve=steve+1
pause 500
run 1
It is easy to handle word variables in this way, because the Stamp
software assigns word variables first in memory in the order they are
defined. Bytes, nibs and bits are a bit trickier. You should define
them as aliases to chunks of word variables. E.g.
steve var word
znavor var word
zna var znavor.byte1
vorA var znavor.byte0.nib1
vor0 var znavor.byte0.bit0
' etc. keeps bytes, nibs and bits in controlled locations
That gives you the most flexibility. "Local" variable definitions
can follow the globals, for temporary use in a bank without trashing
the "global" ones.
I have a writeup on this approach to defining cross-bank variables on
my web site at
http://www.emesystems.com/BS2SX.htm
That is just one way to do it. As Al pointed out, the predefined
variables (w0--w12 or b0--b25) point directly to the 25 sequential
bytes in the main memory and bypass the Stamp's automatic memory
management, and as Jon pointed out, the scratchpad memory also is
addressed as a linear memory array.
The main point is that the contents of the RAM memory is unaffected
by the RUN command.
-- regards,
Tracy Allen
