Analog to Digital
Hello everyone,
I used the standard program to read the 8 channels off of an 8bit
ADC0838 a/d converter. This program I think is by Scott Edwards.
Anyways, I got the circuit up and running and I have connected to two
of the channels an LM35 thermometer. I am curious, the numbers I get
in for each channel are what? Are they the voltage or current? Or are
these numbers the temperature. I always get a "31" in for channel 0
and channel 1. I think something is wrong, but I am not sure. Any help
would be greatly appreciated.
PS - Is anyone ever in the chatroom?
Corey C.
Corey C.
I also have been experimenting with the ADC0834 and LM34 (Fahrenheit ). You
are looking at a linearly voltage.
Goto National Semiconductor for data sheets.
www.national.com
Put LM35 in the search field.
The following is an excerpt for that web site on LM35
The LM35 series are precision integrated-circuit temperature sensors, whose
output voltage is linearly proportional to the Celsius (Centigrade)
temperature. The
LM35 thus has an advantage over linear temperature sensors calibrated in °
Kelvin,
as the user is not required to subtract a large constant voltage from its
output to
obtain convenient Centigrade scaling. The LM35 does not require any external
calibration or trimming to provide typical accuracies of ±¼°C at room
temperature
and ± °C over a full -55 to +150°C temperature range. Low cost is assured by
trimming and calibration at the wafer level. The LM35's low output
impedance,
linear output, and precise inherent calibration make interfacing to readout
or control
circuitry especially easy. It can be used with single power supplies, or
with plus and
minus supplies. As it draws only 60 µA from its supply, it has very low
self-heating,
less than 0.1°C in still air. The LM35 is rated to operate over a -55° to
+150°C
temperature range, while the LM35C is rated for a -40° to +110°C range (-10°
with
improved accuracy). The LM35 series is available packaged in hermetic TO-46
transistor packages, while the LM35C, LM35CA, and LM35D are also available
in
the plastic TO-92 transistor package. The LM35D is also available in an
8-lead
surface mount small outline package and a plastic TO-220 package.
Hope this helps
Bruce Snowden
the_coin_guy@y... wrote:
> Hello everyone,
> Thanks,
> Corey C.
Thank you Bruce for the information. It is greatly appreciated. I was
under the impression that because I had the voltage reference pin on
the adc0838 hooked up to 5v, I would not be getting the exact
temperatures in to the STAMP. I guess not. It seems to be working
fine. On the LM35, I am getting around 22degrees celsius in --> this
is about right. Any information on this Vref pin is still appreciated
however. It confuses me somewhat.
Corey C.
--- In basicstamps@y..., Bruce <bsnowde@a...> wrote:
> Hi Corey
). You
> www.national.com
sensors, whose
> temperature. The
calibrated in °
> Kelvin,
from its
> output to
external
> temperature
assured by
> impedance,
readout
> or control
supplies, or
> with plus and
> self-heating,
-55° to
> +150°C
range (-10°
> with
hermetic TO-46
available
> in
> 8-lead
> Hope this helps
> Bruce Snowden
> > Hello everyone,
> > Thanks,
> > Corey C.
As I understand it, the Vref is to provide a Reference voltage so that the
ADC0831 can use it to make comparison to the voltage coming from the
LM35/LM34.
I take it that you are referring to Scott Edwards book, "Programming and
Customizing The Basic Stamp Computer". He suggest to set the Vref to 2.55
volts. In my circuit mounted on a Experimental board, I had to set it to
2.58 to get the reading from the LM34/ADC0831 to compare to a DVM (digital
volt meter). You can use a DVM and read directly from the LM35 at Vin+. The
DVM set to the right scale, will show the temp. I then adjusted R1 pot so
that the Stamp has the same temp as the DVM. Upon reading the voltage at
Vref, this voltage was 2.58. Close enough, as there could just be some error
in my circuit or DVM.
I am also learning the Basic Stamp. I am currently working on a program
comparing the ADC0831/LM34 to the DS1620 for temperature reading. So if what
I say here is incorrect or can be explain by someone in more elegant way, I
won't be offended.
Bruce Snowden
> Hello,
> Thanks,
> Corey C.
> > Hi Corey
> ). You
> > www.national.com
> sensors, whose
> > temperature. The
> calibrated in °
> > Kelvin,
> from its
> > output to
> external
> > temperature
> assured by
> > impedance,
> readout
> > or control
> supplies, or
> > with plus and
> > self-heating,
> -55° to
> > +150°C
> range (-10°
> > with
> hermetic TO-46
> available
> > in
> > 8-lead
> > Hope this helps
> > Bruce Snowden
> > > Hello everyone,
> > > Thanks,
> > > Corey C.
That makes sense to me. However, when I hooked up some LM35's to the
input channels on the ADC0838 and I had Vref connected to +5v, the
temps came in on my stamp debug screen correctly!? I dont understand
why. Logically, the Vref should have to be connected to 2.55V ???
Corey C.
> Corey,
that the
> LM35/LM34.
to 2.55
it to
(digital
Vin+. The
pot so
voltage at
some error
So if what
way, I
> won't be offended.
> Bruce Snowden
> > Hello,
> > Thanks,
> > Corey C.
> > > Hi Corey
> > ). You
> > > www.national.com
> > sensors, whose
> > > temperature. The
> > calibrated in °
> > > Kelvin,
> > from its
> > > output to
> > external
at room
> > > temperature
> > assured by
> > > impedance,
> > readout
> > > or control
> > supplies, or
> > > with plus and
very low
> > > self-heating,
> > -55° to
> > > +150°C
> > range (-10°
> > > with
> > hermetic TO-46
> > available
> > > in
available in an
> > > 8-lead
> > > Hope this helps
> > > Bruce Snowden
> > > > Hello everyone,
to two
I get
Or are
channel 0
Any help
> > > > Thanks,
> > > > Corey C.
Corey,
When I adjust Vref pot to +5v on my circuit, I get a reading
of 35 F for what should be 70 F. Way off. Are you sure you
are reading the correct leg of the pot ? The wiper leg,
(Center Leg) ?
+5v________/\/\/\/\/\/\________________ GRD
| <- to Vref
Should be set to 2.55V
between the wiper, and GRD
Assuming that you are reading the correct leg of the pot, what
is your reading if you adjust it to 2.55v ?
Bruce
> Bruce,
LM35's to the
+5v, the
understand
2.55V ???
I don't even have a pot on there as it is now. I am getting the
correct temperatures! I just don't understand why? I will try it with
a pot....
Corey
--- In basicstamps@y..., bsnowde@a... wrote:
> --- In basicstamps@y..., the_coin_guy@y... wrote:
> Corey,
> (Center Leg) ?
> | <- to Vref
> Bruce
> > Bruce,
> LM35's to the
> +5v, the
> understand
> 2.55V ???
I am using the ADC0831 as listed on p 119 in Scott Edwards book. For
information and data sheets on both the ADC0831 and ADC0838 go to:
http://www.national.com
I am not sure what the difference of the two are. The ADC0838 look
interesting with up to 8 channels. They both are listed on the same data
sheet. Look at page 14 of the data sheet for a full run down on the Vref.
Briefly, the ADC0803X is 8 bits, giving 256 data points. So ( as I
understand it ) by adjusting Vref to 2.55 v you are allowing each uV to
represent a degree. 0v would also be a data point. (2.55v / 256 data points
= 1 uV per data point)
You may be using a different circuit/program that compensates for the 5V on
Vref then what I am using. ie. Maybe you have a fixed resister in place of
the pot. Or your program could be using an equation to bring the results in
line. Another though that has just occurred to me, You are measuring
Centigrade, where I am measuring Fahrenheit. The Centigrade unit is a larger
unit than the Fahrenheit. This may explain the difference in reference
voltage as you would need a wider voltage range ?? I don't have a Centigrade
LM35 to try on this end.
On another note, Some say if it isn't broke, don't fix it. :-)
I am curious why you have such different results, so let me know what you
find.
Bruce Snowden
> Are you using the ADC0831 or the ADC0838? Maybe there are variances?
> a pot....
> Thanks,
> Corey
> > Corey,
> > (Center Leg) ?
> > | <- to Vref
> > Bruce
> > > Bruce,
> > LM35's to the
> > +5v, the
> > understand
> > 2.55V ???
>a pot....
Maybe you have the shiftin command reading the wrong number of bits.
The effect of that would be a factor of two error in the result.
You can use any reference value, but you have to multiply the A/D raw
result by a constant to convert it to engineering units. For
example, the LM35 puts out 10 millivolts per degree C, and the 8 bit
converter with a 2.56 volt reference has a sensitivity of 2.56/256 =
0.010 volts per bit, so the answer comes out directly in Celsius.
With a 5.12 volt reference, the sensitivity is 5.12/256=0.020 volts
per bit, so a one bit change happens for each 2 degrees C, and you
have to multiply the A/D result times 2 to get the answer.
-- Tracy
>a pot....
-- Tracy
The Celsius vs. Fahrenheit theory is a good one. You are right, it may
have something to do with this. However, both the LM35 and LM34 create
10mV/degree Celsius or Fahrenheit....so...? I will try adjusting the
Vref with a pot and see what happens.
Corey C.
> Corey,
data
Vref.
data points
the 5V on
place of
results in
a larger
Centigrade
what you
> find.
> Bruce Snowden
> > a pot....
> > Thanks,
> > Corey
> > > Corey,
> > > (Center Leg) ?
> > > | <- to Vref
> > > Bruce
> > > > Bruce,
> > > LM35's to the
> > > +5v, the
> > > understand
> > > 2.55V ???
compensate for the 5volt Vref, I would get the wrong temp. If I
multiplied the temperature I am currently getting in by about 2, I get
around 40 degrees Celsius at room temperature! I prefer the 20 degrees
I am getting now!
Confused,
Corey C.
> >a pot....
> -- Tracy
>I am getting now!
What is the exact shiftin command you are using? I am thinking about
the -pre versus -post parameter, which if wrong can give an apparent
x2 factor in the reading.
I am using that standard ADC0838 program by Scott Edwards. So, I dont
think the command would be incorrect, but you can check.
Corey C.
> >Yes, That's what I thought. But if I did the calculations to
> >I am getting now!
I changes the command from shifting in 9 bits to shifting in 8 bits. I
think it now works? Any thoughts on why?
Corey C.
> >I am getting now!
>Thanks,
>Corey C.
Corey,
After looking at the ACC0838 timing, I would try
for channel=0 to 7
command=%1000+channel
low adcs
shiftout dopin,cpin,msbfirst,[noparse][[/noparse]command\5]
shiftin dipin,cpin,msbpost,[noparse][[/noparse]result\8]
high adcs
debug dec channel,tab,dec result
pause 200
next
That is probably similar to what you have now (I have not actually
seen the application note you are referring to). What do you have in
the position of the msbpost? It all has to do with reading the right
number of bits into the result variable.
And from careful reading of the timing diagram in the ADC0838 data
sheet. I am not sure that the above code will work, because I have
not used that part. Sometimes the data sheets are confusing (or
wrong!) and you have to experiment with different combinations of
mode and number of bits. But it is satisfying when you do get your
understanding of SHIFTIN matched up with the published timing diagram.
The timing diagram shows that the ADC0838 takes in the command on the
rising edges of the the first 5 clock pulses after CS goes low.
Subsequently, the most significant bit of the data is clocked out on
the falling edge of the sixth clock pulse. That is the justification
for the msbpost above. That tells the Stamp to read the data _after_
it receives the sixth clock pulse. Another way you could do it is:
shiftin dipin,cpin,msbpre,[noparse][[/noparse]result\9]
In addition to the 8 data bits, the shiftin here reads the dud low
bit that comes out on the falling edge of the 5th clock pulse. Note
that the mode this time is msbpre, and there are 9 bits transferred.
The Stamp reads that dud 9th bit _before_ it receives the sixth clock
pulse.
I hope that helps.
-- regards,
Tracy Allen
http://www.emesystems.com
I haven't followed this thread all the way back but have you looked at
the ADC038.ZIP file in the BS2 library?
http://www.hth.com/filelibrary/BS2-IC/
Adolph Stumpf
astumpf@q...
--- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
> >Tracy,
bits. I
> >Thanks,
> >Corey C.
> Corey,
> for channel=0 to 7
> low adcs
> high adcs
> pause 200
> next
right
diagram.
the
Note
clock
> pulse.
> I hope that helps.
> -- regards,
> Tracy Allen
Thanks a lot! Great help! As for the ADC0838.zip, that's the program I
am using. . . I changes the shiftin 9 bits to shiftin 8...its seems to
work now.
Corey C.
--- In basicstamps@y..., apstumpf@u... wrote:
> Corey,
> Adolph Stumpf
> astumpf@q...
> > >Tracy,
> bits. I
> > >Thanks,
> > >Corey C.
> > Corey,
> > for channel=0 to 7
> > low adcs
> > high adcs
> > pause 200
> > next
> right
> diagram.
> the
> Note
> clock
> > pulse.
> > I hope that helps.
> > -- regards,
> > Tracy Allen
