SMT
Has anyone ot there become adept at soldering surface-mount devices to
boards either at home, or in a small workshop without all the expensive
tools? If so, would you care to share some of the basics?
Suggest you check out recent issue of QST magazine on soldering and handling
SMT devices. I don't recall the issue number. Continue to use precautions
regarding ESD (electro-static dsicharge) on all semiconductor devices.
Good Luck, Burt
good. I'm talking a Weller or Edsyn type iron with a base station. Can
be adjustable, but not necessarily. A very long, pointed tip is what I
prefer, and very fine solder.
I find pre-tinning the pads, or some folks use solder paste,works well.
You need to work quick, and not overheat the part. In particular, ceramic
caps are susceptible to cracking damage, which may not be evident
immediately, but may drive premature failure down the road. Don't try to
accelerate cooling off the part after soldering.
Stew Benedict
It is easy to solder SMT devices without the expensive
equipment. Hand soldering is time consuming and would
be OK for 1 or 2 prototypes.
To hand solder you will need a pair of tweezers, rosin
flux and 0.10" diameter solder.
Procedure:
For Resistors/Capacitors;
1. Apply flux to PCB footprint for component to be
soldered. If you use a rosin flux and allow to dry it
will become tackie. This will help hold the component.
2. Use the tweezers and place the component.
3. Using to 0.010" diam wire solder, lay the solder
along the component lead. Apply heat. Repeat to other
lead.
For IC's
2. Apply solder to one of the IC pads.
3. Use the tweezers and place the component, and hold.
4. Using the soldering iron heat the pad which has to
solder applied and allow solder to flow onto IC pin.
5. Using to 0.010" diam wire solder, lay the solder
along the component leads. Apply heat.
By using the 0.10" diam wire solder you will get the
proper amount of solder to make a good joint.
If you have any other questions please feel free to
contact me directly.
John DeFeo
Director, Engineering
Motion Sensors Inc.
Ph: 252-331-2080
Fax: 252-331-1666
e-mail: jwdefeo@y...
WEB site: http://www.motionsensors.com
--- "Chris Loiacono (E-mail)"
> basics?
__________________________________________________
Do You Yahoo!?
Yahoo! Auctions - Buy the things you want at great prices.
http://auctions.yahoo.com/
for how to solder SMT devices using a toaster oven. Very cool stuff.
http://www.seattlerobotics.org/
To: Basicstamps Egroup (E-mail) <basicstamps@yahoogroups.com>
Sent: Sunday, March 11, 2001 7:36 PM
Subject: [noparse][[/noparse]basicstamps] SMT
refrigerated and because of this you can only get it sent overnight. I don't
know if the wife would let me put solder paste into the fridge....
Al Williams
AWC
* Expand your Stamp I/O: http://www.al-williams.com/awce/pak3.htm
> Go to the Seattle Robotics Society's web page and look in the Encoder
syringes, and sometimes they would last months.. nobody took care of it,
and the worst that would happen is that it would get a bit too thick and
would start to get gummed up.
I think if you just kept it in a relatively cool place (near the A/C
vent?) it should be ok
Jason
Al Williams wrote:
> I've looked into this. The problem is the solder paste has to be kept
> Al Williams
> AWC
Jason Lavoie
jlavoie@e...
jlavoie@o...
ICQ#:10604243
Electrical Engineering III, Carleton University
Why refrigerated? I've not used it before, but sure wouldn't have guessed
that as a requirement.
-- Mitch
sitting on my bench for months (not refrigerated.) I have used the paste
when it was new, and again months later. Of course, I have to mix it each
time, as it seems to separate. I keep the covers screwed on tightly, and
I've not had any trouble with it each time it's been used.
Perhaps someone can clear up the confusion. Are there any paste solder
"experts" out there today?
Chris
> From: M. D. Miller [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oYwhb7a_qPIveCKVP09ftD3AgLI0zm_16ApDNRqu5bKuHQWjHj5BcEL5oUr2Gcezhx4NAO6ugV3k]mdmiller2@h...[/url
> Sent: Tuesday, March 13, 2001 9:08 AM
> Subject: RE: [noparse][[/noparse]basicstamps] SMT
> > solder paste has to be kept refrigerated
> have guessed
> -- Mitch
that were. Several years ago, I used to work at a facility where we
performed research on electronics manufacturing processes and we ALWAYS kept
the solder paste in a refrigerator. I know if it was left out, it had to be
thrown away as it would not perform as it was supposed to during testing.
Since that's one of the things we did was test the different solder
pastes...it made a difference. I've seen the quality of the solder joints
at really high magnification using a S.E.M. (Scanning Electron Microscope)
and old, left out overnight paste didn't produce as nice results. For the
most part, it still worked...but the solder joints had a much higher rate of
failure when subjected to enviornmental extremes. Anyway.....
Kept refridgerated... it will also last a fairly long time.
- Brice
Sent: Tuesday, March 13, 2001 9:26 AM
I have two jars of 50/50 paste made with an aqueous flux - that have been
Chris
> From: M. D. Miller [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ziuOKrFa2uw4dbApJ2ey_-a1GtK7VJkCZ3OaYblYFeMihc9_A7YHcUVhVS96OJcyET34tIr7tPcm]mdmiller2@h...[/url
> have guessed
> -- Mitch
