Power Source
Archiver
I would love to find a fuel cell that could provide 12 volts at 2 amps for a
period of 72 hours. Fueled with something less exotic then liquid hydrogen!
Does such a critter exist? Are there any type of fuel cells available on the
market or do they fall into the 'real soon now' catagory?
Vic
________________________________________________________
Victor Fraenckel - The Windman vfraenc1@n...
KC2GUI www.windsway.com
Home of the WindReader Electronic Theodolite
Read the WIND
Vic
Read the WIND
they do talk about Hydrogen as a fuel - but they might have other things on
offer.
Justin.
From: Vic Fraenckel [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BldMDf2Z0ZoKRiFN-LrKZDWwJHRjaX7_IUCWCVtHQa-JHpwFLe_2S5ZdHJ-fcb-ez7B0RjE9vSEfg_l63Oo]vfraenc1@n...[/url
Sent: 12 March 2001 02:42
To: Basic Stamp List
Subject: [noparse][[/noparse]basicstamps] Power Source
Vic
Read the WIND
http://www.hpower.com
http://plugpower.com
http://ballard.com
and ask - let us know if any are purchasable now... I think
some use reforming of methane or propane to get their hydrogen
source..... good luck
Date: Sun, 11 Mar 2001 21:41:54 -0500
for a
hydrogen!
the
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
w/c provides +15V, 300mA? i need +12V and -12V to power up 3 LF356 opamps and
+5V to power up BASICStamp2 chip. before i used batteries, i used two 9V batts
to powerup the opamps and another 9V to power up the Stamp. The problem is,
batteries run out.
can anyone help me with this?
-Errick
Do you Yahoo!?
Free Pop-Up Blocker - Get it now
http://www.allelectronics.com/cgi-bin/category.cgi?category=480&item=PS-180&type\
=store
http://www.allelectronics.com/cgi-bin/category.cgi?category=480&item=PS-525&type\
=store
http://www.allelectronics.com/cgi-bin/category.cgi?category=480&item=PS-526&type\
=store
Hank Hagquist
HobbyTalk - http://www.hobbytalk.com
Sent: Friday, November 21, 2003 12:08 PM
Subject: [noparse][[/noparse]basicstamps] power source
> how can i derive a +12V, -12V, and +5V to power up my chips from a wall
adapter w/c provides +15V, 300mA? i need +12V and -12V to power up 3 LF356
opamps and +5V to power up BASICStamp2 chip. before i used batteries, i
used two 9V batts to powerup the opamps and another 9V to power up the
Stamp. The problem is, batteries run out.
> -Errick
> Do you Yahoo!?
One way to do it is to use two 12V wall warts. Connect them in series, and
the middle is ground. You can also use an old computer power supply, which
is cleaner and has the -12V.
If you can switch to around -5V instead of -12V for the op-amps, you can
derive the power from the Stamp itself using PWM and a charge pump. This can
be a cool option if you can live with the lower voltage.
Jonathan
www.madlabs.info
Sent: Friday, November 21, 2003 9:08 AM
> -Errick
> Do you Yahoo!?
some game controller replacement supplies that
have a negative pin on them. While you're there,
pick up the matching female DIN connector.
Another approach is to use a small -12 volt
switching regulator which runs off of +5.
Another approach is to use +5 to drive a
MAX232 chip. Use 1.0 uF capacitors, and take
your +- voltage off the Max232 charge pump.
I'm not sure how much current you can use this
way, nor how accurate it is...
--- In basicstamps@yahoogroups.com, Jigorok Ano <gorodaimon321@y...>
wall adapter w/c provides +15V, 300mA? i need +12V and -12V to power
up 3 LF356 opamps and +5V to power up BASICStamp2 chip. before i
used batteries, i used two 9V batts to powerup the opamps and another
9V to power up the Stamp. The problem is, batteries run out.
> -Errick
> Do you Yahoo!?
