still learning
Now I'm actually trying to connect a switch to my stamp, but I'm running
into the low-power reset problem. On my stamp I have an input connected
to ground so that it reads zero, but I want to connect a switch to that
same pin so that when the switch is pushed the pin is pulled high. I
remember there needing to be a resistor in the circut with the power,
switch, and pin, but I don't remember its value.
What is the value of the resistor that needs to be in-line with the
switch to prevent low-power reset of the stamp?
pin to ground, and the switch between the pin and +5 volts. Most of the time
you see a 10k resistor used on TTL stuff, so this might work here also.
If you use the BUTTON command and jump to a subroutine with a return, the
BS2sx will reset. I assume this is true for other BS2 processors. I found
this out yesterday when I was goofing around trying to use the buttons on my
Activity Board.
Sent: Sunday, March 11, 2001 11:20 AM
Subject: [noparse][[/noparse]basicstamps] still learning
> Mike
