OT: Visible Laser?
How does one go about making a visible laser beam with a standard laser
pointer? Is there a filter that you can screw onto the end?
Jordan
Jordan
> Thanks,
> Jordan
if you would like the whole beam to be visible it has to reflect off of
something - like dust or water vapor.
is this what you mean? or do you just want to change the color?
-pete
On Thu, 10 Feb 2000, AC Jacques wrote:
> yes.clear glass.
> > Thanks,
> > Jordan
for a lab with any standard of cleanliness. Same for oil smoke. Steam might
be OK....
I've seen a photographer take a time exposure and wave a sheet of paper thru
the beam to make it visible in the photograph.
Tom O'Brien
a green dot, operating at about 532 nm. They claim that for visible use, it
is 30 times brighter than a 670 nm red pointer. It is expensive. Does anyone
know of other sources for green laser diodes (without a pointer attached)
for OEM use?
Dennis
From: Jordan Wilson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9zmbigxMkonNIc4rfZopbTRftqyn8E1hIsADSg8CxoyIIv9FVpJ21LvvyG0fAFfaTUNimvATnTg8Ym_fUA]bloodspurt@h...[/url
Sent: Saturday, March 10, 2001 12:09 PM
Subject: [noparse][[/noparse]basicstamps] OT: Visible Laser?
Jordan
Are you trying to create a visible line, or just a visible dot?
-Chilton
Jordan
>-Chilton
The cheapy laser pointers come with various clear plastic tips that generate
different patterns. Not sure how that works, but it does.
The other option would be to use a spinning mirror.
Laser?
> I'm trying to create a visible line.
laser diodes, the reason the green is more visible is because the Eye
perceives green better than other colors like red.
"Dennis P. O'Leary" wrote:
> Edmund Scientific (www.edmundoptics.com) sells a visible laser pointer with
> for OEM use?
> Dennis
> From: Jordan Wilson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4m0g83k_3YoegQaoeHxpzICrAQKJ9kl1GnkxvQ4ApAtiNFopUxx5XkAscP5IhDBAiGL8fOFUYW-JpIDbuho]bloodspurt@h...[/url
> Thanks,
> Jordan
deodorizer ( its what I had on hand ) as the vapor drops the line is
visible
Rodent wrote:
> A visible line on a wall or target?
> Laser?
