Port Protection Components
While trolling through the documentation on the Activity Board, I found that
the connection provided for external I/O does not have any port protection
built in. Now that I am expanding beyond my Activity Board as far as I/O, I
need some additional info on how to provide this protection. In looking at
some of the other products and stuff, it looks like they normally put a 10k
resistor in series with the port for most things. Is this correct?
opto's. This pretty much guarantees protection to the stamp. I've
actually connected (by mistake) 230v AC 50Hz to an I/P and whilst it
made the opto smoke a bit, no damage was done!
I've designed a range of plug in modules that provides any external
connections via a standard interface, relay O/P, Opto protected
transistor O/P, Opto protected I/P's, potentiometer I/P's etc.
Let me know if you want more details.
It may not be the cheapest way of protecting the STAMP but does
protect it regardless.
Jon
found that
protection
as I/O, I
looking at
put a 10k
employer, and I want to figure out how to set things up before I complete my
I/O board. I was gonna plug into the connector on the Activity board with a
cable and have a remote board with screw terminals, etc...
Send 'em direct to me -- daweasel@s...
> Depends what type of protection you need, personally I only ever use
how the hell do you attach files to the Post message? I've got 4
schematics for you saved as bmp's.
Jon
> Sure -- send it on. I have a good selection of opto-isolators from
my last
complete my
board with a
use
it
external
icon. This will open a browser to let you pick the file you want to attach.
You can attach all 4 to one message, but have to click on the paperclip for
each file.
Bill...
Sent: Friday, March 09, 2001 4:03 PM
Subject: [noparse][[/noparse]basicstamps] Re: Port Protection Components
> hi Rodent,
> Jon
> my last
> complete my
> board with a
> use
> it
> external
