smoke anyone?
I'm working on a little project that controls a finned air heater with a
stamp. My need is a little OT, but this group seems to have someone for
everything. I want to blow air across my heater with a visible indicator of
the airflow - so I can maximize the amount of air over the heater. I thought
of making some colored smoke in the way it's done for wind tunnell testing.
Does anyone know how to safely generate this kind of smoke?
degree [noparse]:)[/noparse]
Depending on the rate of air movement, perhaps you could use large incense
sticks or cones?
They're cheap, burn a long time, provide quite a bit of smoke, and make
the room smell pretty! *laugh*
-Rich
well [noparse]:)[/noparse]
-Rich
> Thanks, but I've done that on smaller projects, but the air volume is much
> higher now - 40 to 100 cfm. Actually, your idea works well for checking
> suction from free air.
> There is software available to simulate this effect also, but it's super
> costly.
> > From: Richard D. Alloway [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-34rsFN97a9rW0M5TzfRuWO-47IRSJnRCi5xdGoisXh7c2zKOXS_vExg8dS9rKWfFM1-q6Ll]ralloway@h...[/url
> > Sent: Thursday, March 08, 2001 11:44 AM
> > To: Basicstamps Egroup (E-mail)
> > Subject: Re: [noparse][[/noparse]basicstamps] smoke anyone?
> > As a newbie, this is the first post I've been able to answer to some
> > large incense
> > sticks or cones?
> > smoke, and make
> > -Rich
> > heater with a
> > someone for
> > heater. I thought
> > tunnell testing.
costly.
> From: Richard D. Alloway [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4MpBkVx7g4EyGKLUurGSBsGmkm0uOLw515rvIa2cxbEsF_Pp9yRhJZxVYYzctlL71PkdvZS476sGl7w]ralloway@h...[/url
> large incense
> sticks or cones?
> smoke, and make
> -Rich
> heater with a
> someone for
> heater. I thought
> tunnell testing.
LOADS of smoke for about 30 seconds, depending on size.
HTH,
Justin.
From: Richard D. Alloway [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tgU-5ktzHPuThcl7xZ1xJUCqKJd8Kii1HjJ_hvGjj7CF6iaadqwyGa7awJrJCC6Zj9FfWhyfM1St4g]ralloway@h...[/url
Sent: 08 March 2001 16:51
Subject: RE: [noparse][[/noparse]basicstamps] smoke anyone?
Ah...I wasn't sure what your volume was...for small projects this works
-Rich
> costly.
> > large incense
> > sticks or cones?
> > smoke, and make
> > -Rich
> > heater with a
> > someone for
> > heater. I thought
> > tunnell testing.
http://www.forestry-suppliers.com
search for smoke:
> Superior Smoke Generators And Signals
> White to gray colored smoke. High obscuring power.
> Applications include emergency signalling, air-flow studies, leak
> detection, fire-training, photography, and game management.
> Note: Use with caution.
-- Tracy
You could use dry ice, or rent a smoke machine from a magic / costume shop.
> costly.
> > large incense
> > sticks or cones?
> > smoke, and make
> > heater with a
> > someone for
> > heater. I thought
> > tunnell testing.
Do you need to view the actual path of airflow, or just need assurance that
air is indeed flowing? If the latter, small bits of crepe paper or yarn will
"wave in the breeze" quite nicely and indicate direction as well. I've seen
this technique used in wind tunnels and water channel testing. Perhaps by
careful placement of a photo interrupter, a signal could be provided to the
Stamp, to let it know all is well.
--Stu
To: Basicstamps Egroup (E-mail) <basicstamps@yahoogroups.com>
Sent: Thursday, March 08, 2001 10:45 AM
Subject: [noparse][[/noparse]basicstamps] smoke anyone?
of
thought
testing.
This is a great group!
> From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tdrY6fBuiy3BiRaxrc3Y5sMC_X6QdVR7Bte6amLO0WbhgIJZeqJG_DSPchF_xIRPkGF0p7tdtD9S5zo1SBY]tracy@e...[/url
> Sent: Thursday, March 08, 2001 12:24 PM
> heater with a
> someone for
> heater. I thought
> tunnell testing.
> search for smoke:
> -- Tracy
can buy them cheap, I got mine at goodwill..
Leroy
I make single to three phase converters. See:
[url=Http://home.fuse.net/leroy/phase.htm]Http://home.fuse.net/leroy/phase.htm[/url]
http://home.fuse.net/leroy/resume.htm
effects? What I mean is maybe to use small plastic strips or ribbons
that will indicate the direction and velocity(somewhat) of the air?
Just a thought,
Bandit
thought
it by hanging it out the car window.
...Or a small hobby propeller connected to a small motor -- max flow = max
voltage generated by motor.
> Instead of seeing actual air and/or smoke, how about seeing the
a
indicator of
> thought
testing.
Just a thought,
Bandit
thought
D.S.
> To: <basicstamps@yahoogroups.com>
> From: "Dr. Peter Charles" <pcharles@m...>
> Date: Thu, 8 Mar 2001 19:45:00 -0500
> Reply-to: basicstamps@yahoogroups.com
> Subject: RE: [noparse][[/noparse]basicstamps] Re: smoke anyone?
> I know this is probably a violation of my employer's "smoke-free workplace"
> policy but...a good source of small volumes of smoke that can be easily
> localized is a cigarette. I have used them to verify that fume hoods and
> biological safety cabinets are functioning properly. It helps that I am a
> smoker, and tend to have them handy [noparse];)[/noparse]
> Peter C. Charles, Ph.D.
> Research Assistant Professor
> Department of Microbiology and Immunology
> Rm. 730 Mary Ellen Jones Building, CB# 7290
> UNC
> Chapel Hill, NC 27599-7290
> Phone: 919.966.4026
> Fax: 919.962.8103
> Homepage: http://www.med.unc.edu/~pcharles/
all kinds of neat colors. Theatrical shops shold have something.
You can even cut them into smaller pieces for less smoke or shorter
tests.
Forget CO2, or dry ice, it'll dissapate when it moves fast unless
you're only blowing the 'fog'
Dave
> Just a thought,
> Bandit
heater with a
someone for
indicator of
heater. I
> thought
tunnell testing.
UNC
Phone: 919.966.4026
Fax: 919.962.8103
A Stumpf
--- In basicstamps@y..., "Chris Loiacono (E-mail)" <chris01@t...>
with a
for
indicator of
thought
testing.
