Air sensors...
Hello stampers,
Has any body done anything with air pressure sensors ? I wish to be able to check the air pressure in a cylinder with a stamp, either with an ADC or using the rctime method. However I would need good quality sensors as it is a bit of a safety issue.
Any sample code or sensor suppliers in Australia would be appreciated.
Also many thanks for the answers to my current sensing question.
Chris Anderson
Chris Anderson
start at $149. You can pick from several different pressure ranges.
They have three wires: power, ground, and signal. Power can be from 8-16
vdc, regulated. The output signal is a dc value related to the pressure.
At 8 vdc supply, the output ranges from 1-6 vdc. Increasing the supply
voltage porportionally increases the output voltage, so depending on the
max ADC input voltage this output voltage may need to be scaled --
especailly if operating off a high supply voltage. The bad thing about
these sensors is that they have no zero or span adjustments.
BTW, request Omega's Reference Set -- 6 hardback volumes packed with cool
sensors, instrumentation, and technical info -- all for free. Phone is
800-222-2665.
On Thu, 8 Mar 2001 08:18:12 +0800 "Chris Anderson" <fes@g...>
writes:
> Hello stampers,
> appreciated.
> Chris Anderson
