Stamp Selcall decoder
what's selcall?
> From: jbh@x...
> Date: Thu, 08 Mar 2001 01:38:03 -0000
> Reply-to: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Stamp Selcall decoder
> Anyone successfully used the stamp to decode selcall? Want to do this
> but don't want to re-invent the wheel.
> From: jbh@x...
around 1000hz area ,each of 20ms. They use it as an in band
signalling system mainly on radio systems. Its transmitted audibly at
the beginning or the end of a conversation. Used for vehicle
identification or remote controll. Many different uses and many
different formats. Usually hear it on police or emergency service
radio systems.
--- In basicstamps@y..., "Doug Simpson" <veewee77@a...> wrote:
> what's selcall?
> > To: basicstamps@y...
> > From: jbh@x...
> > Reply-to: basicstamps@y...
this
for conventional two-way?
> Short for selective calling. 'Generally' its a series of 6 tones
> radio systems.
the
time with speech. Selcall is sent on trailing edge of speech. Can use
it on any radio system. Railways use it for identification of locos,
base calls, emergency alert, vigalence etc.
Sounds sort of like the tones you hear at the end audio cassette
tapes
but faster.
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> We're talking 800 Mhz trunked radio? Or are you refering to CTCSS
stuff used
audibly
at
> > radio systems.
jbh@x... wrote:
> No. Not talking about CTCSS, thats out of band signalling...on all
> the
> tapes
> but faster.
> stuff used
> audibly
> at
> > > radio systems.
them as 2-way radios.
I don't think decoding this is gonna do much though -- the main stuff on a
trunked radio system is on a separate data-only channel.
> It sounds like a chirp when the mike is released
> > the
> > tapes
> > but faster.
maintain. At the moment we use decoder units which are about $800 a
pop. What I want to do was to use the stamp to copy one of these units
function plus a lot more for a lot less money. We use selcall to poll
our repeaters to query any alarms that appear. This gives use some
indication of what could be wrong before we travel there. We can also
start generators if batteries need a boost.
Stamps can generate selcall nicely but decoding is a little more
complex.
Don't know what Nextel phones are but we only use radios on the
network.
> OK, so it is like the trunked radio stuff and the Nextel phones when
you use
stuff on a
all
> > > the
Can use
locos,
> > > tapes
> > > but faster.
radios. As a 2-way, they have a push-to-talk buttton and you can talk to
other radios on your account. When you key / unkey them they make a series
of audible tones.
> The situation is that we use selcall a lot on the radio system I
> complex.
> network.
> complex.
> network.
> you use
> stuff on a
> all
> > > > the
> Can use
> locos,
> > > > tapes
> > > > but faster.
Selcall has great uses, we use it for telemetry & telecommand.....wonderful
stuff!
experiment 1. Basic Analog and Digital Experiment #6 •••• this allows you
to read frequency may be a bit low for your use
> complex.
> network.
> you use
> stuff on a
> all
> > > > the
> Can use
> locos,
> > > > tapes
> > > > but faster.
> complex.
> network.
> you use
> stuff on a
> all
> > > > the
> Can use
> locos,
> > > > tapes
> > > > but faster.
long this frequency lasts for (20ms) then go straight into decoding
the next five different frequencies.If any of them don't last for 20ms
then it would be classed as a non decode. Sounds simple but how
simple?
A few people have asked how to generate it. The code is as follows.
FREQOUT 0,20,1747
FREQOUT 0,20,1358
FREQOUT 0,20,1124
FREQOUT 0,20,1197
FREQOUT 0,20,1747
FREQOUT 0,40,0
FREQOUT 0,20,1640
This equals code 84128 7 (7 being the status with a pause of 40ms
beforehand)
So as you can see, quite simple.
--- In basicstamps@y..., "L .Gaminde" <lgaminde@t...> wrote:
> could your read this with pulsin command
a
units
poll
also
> > complex.
> > network.
when
> > you use
> > stuff on a
signalling...on
> > all
> > > > > the
speech.
> > Can use
of
> > locos,
cassette
> > > > > tapes
> > > > > but faster.
not in the lookup table is not valid, the count command will run for 1 to
65535 mS give it a shot and let us know what the reading's are
jbh@x... wrote:
> yep. That would get the frequency alright but you also have to see how
> simple?
> FREQOUT 0,20,1747
> FREQOUT 0,20,1358
> FREQOUT 0,20,1124
> FREQOUT 0,20,1197
> FREQOUT 0,20,1747
> FREQOUT 0,40,0
> FREQOUT 0,20,1640
> beforehand)
> a
> units
> poll
> also
> > > complex.
> > > network.
> when
> > > you use
> > > stuff on a
> signalling...on
> > > all
> > > > > > the
> speech.
> > > Can use
> of
> > > locos,
> cassette
> > > > > > tapes
> > > > > > but faster.
thoughts would be that you would have to wait for one of the ten
frequencies to appear then use the count command. Will give it a go
sometime and see how it works.
> Well how about trying the count command and a lookup table if the
value is
1 to
how
decoding
20ms
> > simple?
follows.
> > FREQOUT 0,20,1747
> > FREQOUT 0,20,1358
> > FREQOUT 0,20,1124
> > FREQOUT 0,20,1197
> > FREQOUT 0,20,1747
> > FREQOUT 0,40,0
> > FREQOUT 0,20,1640
> > beforehand)
I
$800
> > a
these
> > units
to
> > poll
some
can
> > also
more
> > > > complex.
the
> > > > network.
phones
> > when
> > > > you use
main
> > > > stuff on a
> > signalling...on
> > > > all
> > > > > > > the
> > speech.
> > > > Can use
identification
> > of
> > > > locos,
> > cassette
> > > > > > > tapes
> > > > > > > but faster.
