small motors?
Does anyone remember the motors used in slot-car games ~25 years ago?
I remember the motors having the wire would around the core and what I
guess was the magnet as a square around the motor. I remember these
motors being small and light. Has anyone tried using one of them
(assuming they're still made and available)?
I haven't got to using motors with BS yet. Still learning code and ADC.
They are still available. Goto you local hobby shop, and take a look. They
come in around $ 10 on up to $ 100 + for the monster power and torque. They
are really an art of motor design. I would think that the biggest problem is
the amount of power they will use. After all, that kind of
power has to come from somewhere.
Bruce Snowden
> Mike
for $20 each. You can get them from a few RPM up to about 150 rpm and they
already have a gearbox and a large shaft. We attached the wheels directly to
the shaft. A MotorMind B will control them and give you almost infinite
speed control. I'm still working on the tach circuit, but so far, so good.
They
They
is
> will control them and give you almost infinite speed control.
That's something I just don't seem to comprehend. How do you connect wheels
to the shafts of a small motor or stepper? In fact, where do you even get
such wheels?
The monster steppers I have (1/4" shaft, or so) have a flattened shaft with
a set screw in the pully. However, all the smaller steppers I have, have a
1/16" (or so) shaft with a gear which appears to be permanently "pressed" ??
onto the shaft.
-- Mitch
have a small lathe at my disposal, I made a hub to fit. The wheels I used
were Razor scooter type wheels. I pressed out the bearings and press-fit the
hub I made into the wheel where the bearing used to be. A thick washer and
bolt on the other side holds the wheel on.
For the smaller motors or servos, you could probably drive another gear that
has a larger shaft, make something to bolt onto the gear, or remove the old
gear and carefully press on something else.
> > We attached the wheels directly to the shaft. A MotorMind B
wheels
> such wheels?
with
a
> onto the shaft.
> -- Mitch
Just drill the hole a little smaller in the plastic wheel hub than the shaft
diameter and press it on. I found that this works really well and have not
had any problems with the wheels slipping. If you want to you can pull the
gear off the end of your small steppers with a small wheel puller if you can
find one but being that the shaft is so small in diameter you could crudely
use 2 screwdrivers to pop off the pressed on gear. just be careful not to
bend the shaft. (note: I have wrecked steppers this way but it usually
works)
Jim
Sent: Thursday, March 08, 2001 10:53 PM
Subject: RE: [noparse][[/noparse]basicstamps] small motors?
wheels
> such wheels?
with
a
> onto the shaft.
> -- Mitch
few dollars.
Cost would be worth it to save one stepper motors.
Bruce
Jim Szymczak wrote:
> I used model airplane wheels once to go ionto the shaft of stepper motors.
> works)
> Regards,
> Jim
> From: "M. D. Miller" <mdmiller2@h...>
> wheels
> > such wheels?
> with
> a
> > onto the shaft.
> > -- Mitch
