rj-11 female connector?
Mike-
Home Depot normally carries good selection of RJ-11 sockets, plugs,
Cat 5 wire, etc. Also good for 1-Wire bus projects with the BS2p.
Steve
On 6 Mar 01 at 21:49, Mike Eggleston wrote:
> I want to use rj-11's...Does anyone have any ideas where to find
> the female connectors?
Steve
from my pc to breadboards, bots, etc., but haven't found any rj-11
female connections. Its easy to find the male parts to crimp on wires,
but not the female sockets.
Does anyone have any ideas where to find the female connectors?
supplies. CAT5 type stuff... They'll have the RJ-11 parts too. If you find
a place that sells the female sockets that can be soldered to a PC
board...please let me know. I've thought about unsoldering them from old
network cards and modems...
Later,
Brice
Sent: Tuesday, March 06, 2001 10:49 PM
Subject: [noparse][[/noparse]basicstamps] rj-11 female connector?
I want to use rj-11's (unless someone has a better idea) for connecting
RJ11 P/C board mount jack. They have other types bit I use this one.
Don Zacharie
> From: Mike Eggleston <mikee@m...>
> Mike
Awhile ago I bought some solder-type RJ-45 jacks with 2 built in LEDs for
about 1.59$ each.. I'm sure I saw RJ-11 solder type
Sent: Tuesday, March 06, 2001 10:52 PM
Subject: Re: [noparse][[/noparse]basicstamps] rj-11 female connector?
> Look for any place that sells telecommunication and data communication
find
> Later,
> Brice
> Mike
Te: 1 (800) 344-4539
This will give you the order desk, ask for technical if you have trouble
describing your needs
Larry
lwindrem@p...
> Mike
Bob Baxter
>Later,
>Brice
>Mike
wind up plugging something in that doesn't belong. I've seen this happen
time and time again when someone uses parts that come to hand.
In this case it might be a bad thing if someone plugged your stuff into a
live phone jack, which can carry anywhere from about 45 volts DC to 90 volts
AC.
> DigiKey, pages 94&95 of their current catalog.
find
DigiKey (800/344-4539) www.Digikey.com
both have broad selections of these modular connectors.
Steve
Steve Roberts: sroberts@s...
You've probably already found and bought some of these already... but here's
another source:
B.G. Micro
http://www.bgmicro.com
Receiver phone connector. PC board mount
ACS1133
$0.39 or 3/$1.00
RJ45 8-wire PC board connector
ACS1132
$0.42 or 3/$1.10
Later,
Brice
at the base that can be easy breadboarded or soldered even. I'm not
sure if you have these stores up in your area.
But, also on a side note, I'm using male plug in my minature robot
and a female connector from teh computer's serial cable. Please see
my site at http://nagi.crosscity.com/basicstamp/alibe.
thx
nagi
connecting
wires,
> Mike
