Bs2p and 1 wire?
On 6 Mar 01 at 20:53, Robert Kubichek wrote:
> I was wondering if anyone can help me with the code for reading more
> than 1 device on the 1 wire buss??? I would like to read multiple
> DS1820 chips...
You'll need to know the 8-byte serial ID for each device and use the
appropriate ID with MATCH ROM commands to select the desired device.
You can visually read the ID on most iButtons. For devices like the
DS1820, the following program will read a device's serial ID out of the
lasered ROM (there must be one and only one device on the bus when this
program runs!)
I hope this helps,
Steve
' Serial Number Extractor
READ_ROM CON $33
' I/O pin constants
BUS CON 15 ' 1-Wire bus I/O pin
' conventional variables
in_byte VAR BYTE(10)
i VAR BYTE
' read ROM-based identifier...this will work with any 1-Wire device...
' assumes one and only one device present on bus...
' 1-Wire transactions summary:
' ---> [noparse][[/noparse]reset]
' ---> READ ROM
' <--- 8 Serial # identifier bytes
OWOUT BUS,1,[noparse][[/noparse]$33] ' send READ ROM
OWIN BUS,0,[noparse][[/noparse]STR in_byte\8] ' read 8-byte serial identifier
DEBUG CR,"Serial # "
FOR i = 7 TO 0 ' display identifier high order
DEBUG HEX2 in_byte(i) ' byte first
NEXT
Make a note of each ID. The following program shows one way to use
them, and shows most of the tricks a DS18S20 knows.
' DS18S20 Digital Thermometer/DS1920 Temperature iButton
' Universal 1-Wire ROM commands
READ_ROM CON $33
SKIP_ROM CON $CC
MATCH_ROM CON $55
SEARCH_ROM CON $F0
SEARCH_FUNC CON $EC
' I/O pin constants
' OWIN, OWOUT constants
RESET_NONE CON 0
RESET_PRE CON 1
RESET_POST CON 2
RESET_BOTH CON 3
temperature VAR WORD
current_device VAR NIB
io_bytes VAR BYTE(10)
i VAR BYTE
j VAR BYTE
' define 8-byte serial identifiers for each device...family code first,
' then low order thru high order serial number, finally crc byte
thermo_1 DATA $10,$7E,$85,$48,$00,$00,$00,$95
thermo_2 DATA $10,$8F,$94,$48,$00,$00,$00,$61
devices CON 2
' Load the serial ID's into scratchpad RAM for easy recall
FOR i = 0 TO 8 * devices - 1
READ i,j
PUT 100 + i,j
NEXT
current_device = 0
GOSUB readTemperature
GOSUB showScratchpad
GOSUB readPower
GOSUB setAlarmLimits
current_device = 1
STOP
readTemperature:
' get temperature data, convert from Centigrade to Farenheit...
' ---> MATCH ROM
' ---> 8 serial # identifier bytes
' ---> CONVERT command
' [noparse][[/noparse]pause]
' ---> MATCH ROM
' ---> READ SCRATCHPAD command
' <--- 9 data bytes
GOSUB selectDevice ' select device with MATCH ROM
OWOUT BUS,RESET_NONE,[noparse][[/noparse]$44] ' send convert command
PAUSE 750 ' allow conversion to complete
OWOUT BUS,RESET_NONE,[noparse][[/noparse]$BE] ' send scratchpad read command
OWIN BUS,RESET_NONE,[noparse][[/noparse]temperature.LOWBYTE,temperature.HIGHBYTE] ' read
OWIN BUS,RESET_NONE,[noparse][[/noparse]STR io_bytes\7] ' scratchpad data
DEBUG CR,CR,"Temperature: ": GOSUB centigradeToFarenheit
RETURN
setAlarmLimits:
' set alarm upper and lower limits, show new scratchpad data, verify CRC:
' ---> MATCH ROM
' ---> WRITE SCRATCHPAD command
' ---> 2 bytes (high temperature alarm, low temperature alarm)
' ---> MATCH ROM
' <--- 9 data bytes
' ---> MATCH ROM
' ---> COPY SCRATCHPAD command
' ---> MATCH ROM
' ---> RECALL E^2 command
' ---> MATCH ROM
' <--- 9 data bytes
OWOUT BUS,RESET_NONE,[noparse][[/noparse]$4E,$50,$10] ' send write scratchpad command, data
OWIN BUS,RESET_NONE,[noparse][[/noparse]STR io_bytes\9] ' read in scratchpad data
DEBUG CR,CR,"DS18S20 temperature limits:"
DEBUG CR,"TH: ",DEC io_bytes(2),CR,"TL: ",DEC io_bytes(3)
OWOUT BUS,RESET_NONE,[noparse][[/noparse]$48] ' send scratchpad copy command
PAUSE 750
OWOUT BUS,RESET_NONE,[noparse][[/noparse]$B8] ' send recall e^2 to scratchpad command
OWOUT BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$BE] ' command scratchpad read
RETURN
readPower:
' read power supply status
' ---> MATCH ROM
' ---> READ POWER SUPPLY command
' <--- 1 data byte (really need just one bit, but...)
OWOUT BUS,RESET_NONE,[noparse][[/noparse]$B4] ' send read power supply command
OWIN BUS,RESET_NONE,[noparse][[/noparse]io_bytes] ' read in power supply status
DEBUG CR,CR,"DS18S20 power supply status: "
DEBUG BIN1 io_bytes,CR
RETURN
centigradeToFarenheit:
' if temperature is negative deg C, use absolute value in applying
' formula...deg F = deg C * 9 / 5 = (2 * deg C) * 9 / 10...if Farenheit
' < 0, show '-' and display absolute value
i = temperature.HIGHBYTE.HIGHBIT ' 1 if deg Celsius negative else 0
temperature = temperature ^ (i * $FFFF) + i * 9 / 10 ^ (i * $FFFF) + i + 32
i = temperature.HIGHBYTE.HIGHBIT ' 1 if deg Farenheit negative else 0
DEBUG "-" - " " * i + " ", DEC (temperature ^ (i * $FFFF) + i)," "
RETURN
selectDevice:
' send match rom and serial ID associated with current_device
FOR i = 0 TO 7
j = current_device * 8 + i
GET 100 + j,io_bytes(i)
NEXT
OWOUT BUS,RESET_PRE,[noparse][[/noparse]MATCH_ROM,STR io_bytes\8]
RETURN
showScratchpad:
' display temperature alarm limits, counts, crc, reserved bytes
DEBUG CR,"DS18S20 scratchpad data:"
DEBUG CR,"TH: ",DEC io_bytes," TL: ",DEC io_bytes(1)
DEBUG CR,"CR: ",DEC io_bytes(4)," CP: ",DEC io_bytes(5)
DEBUG CR,"CRC:",DEC io_bytes(6)," Res: ",HEX2 io_bytes(2),HEX2 io_bytes(3)
RETURN
> DS1820 chips...
program runs!)
I hope this helps,
Steve
READ_ROM CON $33
' I/O pin constants
i VAR BYTE
' ---> READ ROM
NEXT
READ_ROM CON $33
SKIP_ROM CON $CC
MATCH_ROM CON $55
SEARCH_ROM CON $F0
SEARCH_FUNC CON $EC
' I/O pin constants
RESET_NONE CON 0
RESET_PRE CON 1
RESET_POST CON 2
RESET_BOTH CON 3
i VAR BYTE
j VAR BYTE
devices CON 2
READ i,j
PUT 100 + i,j
NEXT
current_device = 0
GOSUB readPower
current_device = 1
STOP
readTemperature:
' ---> MATCH ROM
' ---> MATCH ROM
' <--- 9 data bytes
RETURN
setAlarmLimits:
' ---> MATCH ROM
' ---> MATCH ROM
' <--- 9 data bytes
' ---> MATCH ROM
' ---> MATCH ROM
' ---> MATCH ROM
' <--- 9 data bytes
PAUSE 750
RETURN
readPower:
' ---> MATCH ROM
RETURN
RETURN
selectDevice:
FOR i = 0 TO 7
NEXT
RETURN
showScratchpad:
RETURN
DS1820 chips. There is not much info in the latest manual.
Thanks!
Robert Kubichek N9LVU
bobn9lvu@lakefield.net writes:
than 1 device on the 1 wire buss??? ·I would like to read multiple
Thanks!
Yes this would be helpful, (Im strictly a hobbyist) and I would like to see
some code for other 1-wire devices also, reading files , etc. Thanks also.
Lou[/font]
You need to know the serial numbers for each device. Once known, here's how
you do it. ·This code handles two sensors and can easily be updated to handle
any number of sensors you have. ·This demo also shows effective use of the
BS2p LCDOUT command.
[noparse][[/noparse] Title ]
' File...... DS1820-2.BSP
' Purpose... BS2p <--> Multiple DS1820s Demo
' Author.... Jon Williams
' E-mail.... jonwms@aol.com
' Started... 04 NOV 2000
' Updated... 25 JAN 2001
' {$STAMP BS2p}
[noparse][[/noparse] Program Description ]
' This program reads and displays the temperature from multiple DS1820
' (1-wire) sensors.
' Program requires 2x16 LCD
' ··- LCD.E --> Pin0 (pulled down [noparse][[/noparse]to ground] through 4.7K)
' ··- LCD.R/W --> Pin2 (or grounded for write-only operation)
' ··- LCD.RS --> Pin3
' ··- LCD.D4 --> Pin4
' ··- LCD.D5 --> Pin5
' ··- LCD.D6 --> Pin6
' ··- LCD.D7 --> Pin7
[noparse][[/noparse] Revision History ]
[noparse][[/noparse] I/O Definitions ]
LCDpin CON 0 ' data on pins 4 - 7
DS1820pin CON 15 ' DS1820 bus on pin 15
[noparse][[/noparse] Constants ]
' LCD control characters
NoCmd CON $00 ' just print
ClrLCD · CON $01 ············ ' clear the LCD
CrsrHm · CON $02 ············ ' cursor home
CrsrLf · CON $10 ············ ' cursor left
CrsrRt · CON $14 ' move cursor right
DispLf · CON $18 ' shift display left
DispRt · CON $1C ' shift displayright
DDRam ·· CON $80 ' Display Data RAM control
Line1 CON $80 ' address of line 1
Line2 CON $C0 ' address of line 2
DegSym CON 223 ' degrees symbol
' 1-Wire Support
OW_FERst CON %0001 ' Front-End Reset
OW_BERst CON %0010 ' Back-End Reset
OW_BitMode CON %0100
OW_HighSpd CON %1000
ReadROM CON $33 ' read ID, serial num, CRC
MatchROM CON $55 ' look for specific device
SkipROM CON $CC ' skip ROM (one device)
SearchROM CON $F0 ' search
' DS1820 control
ConvertTemp CON $44 ' do temperature conversion
ReadScratch CON $BE ' read DS1820 scratchpad
NumSensors CON 2 ' number of DS1820s
[noparse][[/noparse] Variables ]
sensor VAR Byte ' sensor number to process
idx VAR Byte ' loop counter
eeAddr VAR Byte ' ee address of ROM match
romData VAR Byte(8) ' ROM data to DS1820
tempIn VAR Word ' raw temperature
sign VAR tempIn.Bit8 ' 1 = negative temperature
tInLow VAR tempIn.LowByte
tInHigh VAR tempIn.HighByte
tSign VAR Bit
tempC VAR Word ' Celsius
tempF VAR Word ' Fahrenheit
rjNum VAR tempIn ' right justified number
rjSign VAR Bit ' sign for rj number
pos VAR Byte ' position to print
digits VAR Nib ' digits in rjNum
width VAR Nib ' width of display
[noparse][[/noparse] EEPROM Data ]
' ROM codes for connected sensors
Temp1 DATA $10,$C9,$70,$45,$00,$00,$00,$FE
Temp2 DATA $10,$81,$CF,$45,$00,$00,$00,$0A
[noparse][[/noparse] Initialization ]
LCD_Setup:
·PAUSE 500
·LCDCMD LCDpin,%00110000 : PAUSE 5 ' 8-bit mode
·LCDCMD LCDpin,%00110000 : PAUSE 0
·LCDCMD LCDpin,%00100000 ' 4-bit mode
·LCDCMD LCDpin,%00101000 ' 2-line mode
·LCDCMD LCDpin,%00001100 ' no crsr, no blink
·LCDCMD LCDpin,%00000110 ' inc crsr, no disp shift
[noparse][[/noparse] Main Code ]
Main:
·LCDOUT LCDpin,ClrLCD,[noparse][[/noparse]"BSP <---> DS1820"]
·LCDOUT LCDpin,Line2, [noparse][[/noparse]"Multiple Sensors"]
·PAUSE 2000
·LCDCMD LCDpin,ClrLCD
ShowDS1820s:
·LOOKUP sensor,[noparse][[/noparse]Temp1,Temp2],eeAddr ' point to ROM code
·GOSUB GetTemp
·LCDOUT LCDpin,Line1,[noparse][[/noparse]"Sensor ",("1"+sensor),":"]
·PAUSE 1000
·sensor = sensor + 1 // NumSensors ' loop through all sensors
·GOTO ShowDS1820s
·END
[noparse][[/noparse] Subroutines ]
GetTemp:
·FOR idx = 0 TO 7 ' load ROM pattern
···READ (eeAddr+idx),romData(idx)
·NEXT
·OWOUT DS1820pin,OW_FERst,[noparse][[/noparse]MatchROM,STR romData\8,ConvertTemp]
WaitForConversion:
·PAUSE 20
·OWIN DS1820pin,OW_BitMode,[noparse][[/noparse]tempIn]
·IF tempIn = 0 THEN WaitForConversion
·OWOUT DS1820pin,OW_FERst,[noparse][[/noparse]MatchROM,STR romData\8,ReadScratch]
·OWIN ·DS1820pin,OW_BERst,[noparse][[/noparse]tInLow,tInHigh]
·tSign = sign ' save sign bit
·tempIn = tempIn/2 ' round to whole degrees
·IF tSign = 0 THEN NoNeg1
·tempIn = tempIn | $FF00 ' extend sign bits for negs
NoNeg1:
·tempC = tempIn ' save Celsius value
·tempIn = tempIn */ $01CC ' multiply by 1.8
·IF tSign = 0 THEN NoNeg2 ' if neg, extend sign bits
NoNeg2:
·tempF = tempIn+32 ' finish C -> F conversion
ShowTemps:
·rjNum = tempC : width = 4 : pos = Line1+10
·GOSUB RJ_Print
·LCDOUT LCDpin,NoCmd,[noparse][[/noparse]DegSym,"C"]
·rjNum = tempF : width = 4 : pos = Line2+10
·GOSUB RJ_Print
·LCDOUT LCDpin,NoCmd,[noparse][[/noparse]DegSym,"F"]
·RETURN
RJ_Print:
·rjSign = rjNum.Bit15
·rjNum = ABS(rjNum)
·digits = width
·LOOKDOWN rjNum,<[noparse][[/noparse]0,10,100,1000,65535],digits
·LCDOUT LCDpin,pos,[noparse][[/noparse]REP " "\(width-digits-1),13 * rjSign + " ",DEC rjNum]
·RETURN
[/font]
This relates to mine previous question. I'm playing with an iButton (the
thermochron) on a PC. By the way, I love it, it's the cat's meow. IButtons
have two connections, a ground and a data/power. How does one connect an
iButton to the BS2P?
Paul
pverhage@sd131.k12.id.us writes:
thermochron) on a PC. ·By the way, I love it, it's the cat's meow. ·IButtons
have two connections, a ground and a data/power. ·How does one connect an
The ground connection is obvious. ·The power/data connection is sent to a
BS2p pin (your OW bus pin) and is also pulled-up to +5 volts through a 4.7K
resistor. ·The BS2p makes 1-Wire a breeze.
I just submitted my April column to Nuts & Volts: the subject is how to do a
search for 1-Wire devices with the BS2p. ·With this code (no, I can't release
it publicly until it's printed...), you can determine how many and what types
of 1-Wire devices are connected to the Stamp (also does a CRC check). ·The
serial numbers of found devices are stored in EEPROM so you can individually
access them (as in Steve's demo).
-- Jon Williams
-- Dallas, TX[/font]
resistor. The BS2p makes 1-Wire a breeze.
** That's what I was thinking, thanks for the explanation.
I just submitted my April column to Nuts & Volts.
** I'll keep my eyes open for it.
Paul
