BS-1 Novice help
[font=arial,helvetica]Hello Stampers,
················I have a quick question about the BS-1 Is there a way that i
can make a pin high and then check the status of that pin....?
symbol pino =switch
Test:
······high switch
······pause 1000
······if switch = 1 then alarm
········goto test
alarm: high 5
·······pause 5000
·······goto test
can this be done.....?....
Thank you[/font]
symbol pino =switch
Test:
······high switch
······pause 1000
········goto test
alarm: high 5
·······pause 5000
·······goto test
Thank you[/font]
So:
high pin0
if pin0=1 then foo ' always goes to foo
What are you trying to do? Maybe that will let us tell you a better answer.
Al Williams
AWC
From: ARTICALEX@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oqUmSqXR_O9NmAcW5O130ocNQGrWh6M4TvAusHnrXOR9bNZtJ6wCp3w2dq5098dOh7xbWhPIMQ]ARTICALEX@a...[/url
Sent: Tuesday, March 06, 2001 4:07 AM
Subject: [noparse][[/noparse]basicstamps] BS-1 Novice help
Hello Stampers,
symbol pino =switch
Test:
high switch
pause 1000
goto test
alarm: high 5
pause 5000
goto test
Thank you
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
········How ·are you..? THank you for ur help , I kinda figure it out but I
do have another question... How can I use the serial out to display a message
on an LCD Screen. Do I have to get a ··Lcd display with certain specs..?
once again thank u
Wendell
[/font]
Chris
Sent: Thursday, March 08, 2001 11:05 AM
Subject: Re: [noparse][[/noparse]basicstamps] BS-1 Novice help
[font=arial,helvetica]Hi, Al,
once again thank u
Wendell
[/font]
great product and great support.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
From: ARTICALEX@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aIb0LnZ31T0lSz6gb6e-CiYJRbReUGi8pv7QuCsb0VcMmCqV5dr5EHAPIMwxtgXiiykFxzT677bx]ARTICALEX@a...[/url
Sent: Wednesday, March 07, 2001 9:06 PM
Hi, Al,
How are you..? THank you for ur help , I kinda figure it out but I
message
on an LCD Screen. Do I have to get a Lcd display with certain specs..?
once again thank u
Wendell
