IR detector problems
Can anyone suggest how to stop my ir detector from oscillating when there is
no ir around for it to detect?
I am using the ir detector sold by radio shack as part no. 276-137b, i
believe this is the Sharp type commonly used as a simple sensor for robot
obstacle detection.
When the detector 'sees' ir from my led's it outputs a clean 0v, however
when it is 'looking' for ir, it oscillates at a high frequency. This effect
is playing havoc with my ability to detect the transistion form hi to lo.
The detector is linked to a BS1 pin directly, i have tried decoupling the
supply and using pull-up resistor(s) with no luck.
Literature suggests the technique I am using to be correct, does anyone have
practical experience??
Any suggestions gratefully received.
Thanks, Steve Pocock
obstacle detection.
Try putting short tubes over both the emitter and detector or cover the
detector with something to filter out visible light.
Have you downloaded the data sheet from Radio Shack's web page?
is
> obstacle detection.
effect
that sort of problem.
How I solved it, though, was using an if/next loop, like so: (BS2
code)
VAR REPS BYTE
FOR REPS = 1 TO 12
IF IN1 = 1 THEN NOTHING
NEXT
DEBUG "OBJECT DETECTED",CR
NOTHING:
DEBUG "NO OBJECT DETECTED",CR
This way, if you get 12 consecutive zeros, the stamp will know that
there is a clear signal, and if there are not 12 consecutive zeros,
it will know that there is nothing.
I found that this works really well, and has solved my problems of
false readings. You can play around with the number of reps.... (I
used 12 because it seemed to work best for me)
Well, I hope that helps!
cyz
~Roger~
TenFour
http://korus.cjb.net
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> It might be picking up IR from other sources.
the
when there
> is
137b, i
for robot
> > obstacle detection.
however
This
> effect
hi to lo.
decoupling the
junk). You might try a bypass capacitor across Vcc and Gnd (i think a 1 uF
will do it) I found these detectors to false trigger due to sunlight,
incandescent bulbs that are being dimmed, and even flourescent lighting.
These junky detectors were used on a robot that I am rebuilding and their
solution was to use the output to chanrge a capacitor and use an LM741 op
amp as a comparitor to output a 0 or 5V voltage depending on if the
capacitor reached a certain threshold voltage that they chose.
They also sampled the output of the detector 10 times and chose the low or
high value as the one that was sampled the most.
The detectors I am using now work much better and don't require and of this
extra circuitry or code to distinguish between low and high (and they are
MUCH smaller and 1/3 the cost). I will never use the Radio Shack detectors
again. To me they are a big headache and a waste of time.
Regards, Jim
is
> obstacle detection.
effect
have
Jim
> I've tested these Radio Shack detectors (and I think thay are overpriced
uF
this
detectors
> Regards, Jim
there
> is
robot
> > obstacle detection.
> effect
lo.
the
> have
Please quote the model and where to find it, I have just the same problem with
the RS junk.
Thanks in advance
ECO
Sent: lundi 5 mars 2001 00:14
Subject: Re: [noparse][[/noparse]basicstamps] IR detector problems
> junk).
Clark at http://www.al-williams.com/wd5gnr/stampfaq.htm#s2.34
(the Basic Stamp FAQ).
Off topic... if you want to see our latest Lego robot (my son Patrick is
having a blast) have a look at
http://www.al-williams.com/wd5gnr/droid.htm -- still no Basic Stamp
controller because I've been too busy, but maybe soon.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
> From: ECO [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EiVI7Zsf9h_qV8q_NxrsEsZ4pSDZDFNTu5-fPQT4xKE_uXdK3AmnWHvBZ-pmQEx-b-mQMGuNA805n3BOZQ]ecourt@b...[/url
> Sent: Monday, March 05, 2001 4:59 AM
> Jim
> problem with the RS junk.
> Thanks in advance
> ECO
> From: "Jim Szymczak" <szymczak@c...>
> > junk).
> and of this
> (and they are
were $1.35 each in July of 2000 when I bought them a few months ago, now
they are $1.53. Use a 0.1 uF cap across Vcc and gnd up close to the chip
and you are done! (of course you need a 36 kHz oscillator which I made out
of a 555) Size, cost, and reliability makes this unit the winner in my
book. I have reduced the size of my headaches greatly when I switched to
this detector [noparse]:)[/noparse]
I also tested digikey part number 160-1162-ND. This is a slighly larger
package (and made out of metal) then the first part and I found that it
works very equivelent to the PNA4602M-ND (but I thought the PNA chip worked
a bit better). I paid $2.15 for this unit. I am not sure if this unit is
still available from digikey as the part search comes up empty.
> Jim
with the RS junk.
> Thanks in advance
> ECO
> > junk).
this
are
Jim
> Ok, the part that I choose to use is digikey part number PNA4602M-ND.
They
worked
> > Jim
problem
> with the RS junk.
> > Thanks in advance
> > ECO
overpriced
> > > junk).
> this
> are
My name is Nagi Babu. I'm in the process of re-designing my micro-
robot called, ALIBE (Artificial LIfe BEing). I'm kinda stuck with
something and was hoping if your esteemed experiences could give me a
helping hand with.
I want to use BS2 to send and receive IR data using Serout and Serin.
I know how these commands work, but, am having trouble with finding
the right product to use. I looked at some products from Sharp. But,
they prove way to big (in size) for my project size.
I was reading the app notes # 11 for BS1 in the BS2 manual. They talk
abt using GP1U52X as a receiver and an IR Emitter for Tx. I bought
the GP1U52X (RS-276-137) from Radio Shack, assembled as suggested. I
used 2 separate circuits with a BS2 in each circuit for send and
receive. But, seems like my Trans is not working. I think my receiver
is kinda working. I came to this conclusion because, when I tried
pointing and clicking my spare Remote Controller for one Pioneer prod
onto the receiver, it did receive something from the RC and spit data
out to the debug window.
I'd like to go with small package Tx and Rx package if possible at
all.
Any help is much appreciated. I'm sure you're very busy with your
usual stuff. I'd really appreciate if you could show me some thoughts
and ideas.
Thanks again in Advance.
Nagi Babu
http://nagi.crosscity.com
http://nagi.crosscity.com/basicstamp/alibe
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> There is a nice discussion of IR detector models and prices from
Dennis
Patrick is
> Regards,
> Al Williams
> AWC
microcontroller:
> > From: ECO [noparse][[/noparse]mailto:ecourt@b...]
> > To: basicstamps@y...
> > Jim
> > Thanks in advance
> > ECO
> > To: <basicstamps@y...>
overpriced
> > > junk).
> > and of this
> > (and they are
Hate to be a bug. Do you have the circuit that I can try, or is it
something that I should go thru your book?
thanks again
nagi
ND. They
ago, now
the chip
made out
in my
switched to
larger
that it
chip worked
unit is
> > Jim
problem
> with the RS junk.
> > Thanks in advance
> > ECO
overpriced
> > > junk).
and of
> this
(and they
> are
Have a look at these pages:
http://www.rentron.com/Infrared_Remote_Control.htm
http://www.rentron.com/Infrared_Communication.htm
We have complete parts kits for using the Stamp to send & receive serial data
by infrared at 1200 to 2400 baud using simple SEROUT/SERIN commands.
Here's a 3-page schematic showing how to build several infrared remote control
systems using Holtek 4-bit & 8-bit encoder/decoders, and a circuit for sending
and receiving infrared data between two Stamps.
http://www.rentron.com/Files/ir-sch4.pdf
- Bruce
webmaster@r...
you with more questions - if that's okay.
nagi
--- In basicstamps@y..., "Webmaster@r..." <breyno2@r...> wrote:
> Hello Nagi,
Serin.
finding
But,
serial data
remote control
for sending
> Regards,
> - Bruce
> webmaster@r...
> Thanks a lot Bruce. I shall read thru the content and will bump into
You're welcome - and I'll be happy to answer any questions you have......
If you don't feel like building this yourself, wait about 4-days. I'll have
Fire-Stick II, and III ready.
Fire-Stick II takes serial data from the Stamp, and sends it out via
infrared (up to 100') at 1200-2400 baud. All you need for the receiver
is a simple IR detector module. Runs from a 9-volt battery, and will
even power your Stamp...
Fire-Stick III turns a standard 12-key matrix keypad into an infrared
keypad. The receiver requirements are the same - a simple IR detector
module.
- Bruce
webmaster@r...
> nagi
> > Hello Nagi,
> Serin.
> finding
> But,
> serial data
> remote control
> for sending
> > Regards,
> > - Bruce
> > webmaster@r...
) The stamp may be just a bit too slow ( bs2 ) some of the new stamps may
work just fine I used PBP and a 16f84 running at 10 mhz for this project
and a scope was a real bonus.
The sony codes go something like this they start with a leader of about
2.20 mS they have a synch bit ( idle at 0 ) for .55 mS and the pulses are
read low, 0 = .55 mS and 1 = 1.10 mS, so idle at the 0 volts state and
pulses low .55 mS for 0 and pulses low for 1.10 mS for a 1.
You may use 13 pulsin statements one looks for leader if it is not in the
correct time frame go back and look again until it's around 2.20 mS or even
2 mS this may give the stamp time for a if statement to check the length,
Read_Leader
pulsin 8,0,leader
if leader = 1000 then Read_Data
goto Read_Leader
Read_Data
use 12 more pulsin statements here and look for values of 250 for 0 and 500
for 1 this is guessing on the 2uS timing of a bs2 I used a loop here the
stamp could not handle the timing.
good luck let me know if I can help
Larry Gaminde
nags@c... wrote:
> Hello EveryBody,
> helping hand with.
> all.
> and ideas.
> Nagi Babu
> Dennis
> Patrick is
> > Regards,
> > Al Williams
> > AWC
> microcontroller:
> > > Jim
> > > Thanks in advance
> > > ECO
> overpriced
> > > > junk).
> > > and of this
> > > (and they are
