MotorMind
Anyone using these things? I thought they would be good to use until I could
build a dual motor controller, but when I got one and read the documentation
I found out their 2 amp continuous rating was with a fan. Talk about
misleading advertising.
The motor mind module only gets mildly warm and no air from the fan can flow
over the heatsink.
If you feel froggy you can pop it into the freezer for 1 minute, pop the
original heat sink off, and put a bigger one on with thermally-better epoxy.
the heat sink on my motor mind was a fraction of a cm higher on one side
when I got it, and it had a good 1mm+ of epoxy between the chip and the
heatsink. Not very good for thermal transfer, but I guess it works.
Robert Staph, KB3FXS
Sent: Thursday, March 01, 2001 8:49 PM
Subject: [noparse][[/noparse]basicstamps] MotorMind
could
documentation
when we get our motor control boards built. Unfortunately I have not tested
the stall current on my drive motors yet.
We scammed a schematic for a gel-cell charger if anyone is interested --
seems to work OK but uses a $7 chip.
> I use one of these to drive a fan, its .6amps
flow
> over the heatsink.
epoxy.
> could
> documentation
