Wireless Temperatures arround the house
Hi
I'm looking for the cheapest way of sending
temperature readings from rooms all around my house
to control my zonal central heating system.
I'm looking for anything that can send a wireless temperature related
signal, be it digital or analogue, (can be calibrated or converted to
temperature reading at reciever by STAMP) to a central reciever that
can understand recieving several temperatures from different
transmitters.
Example
Many Transmitters sending say a resistance related signal and a Room
code to a Central Reciever that can sort the Room Signals out and
convert the Resistance to Degrees.
Must be cheap <$10 per room temperature ?
Any pointers would be greatful
Cheers
Chris
transmitters.
Example
Cheers
Chris
Christopher_Hill@MSN.Com writes:
transmitters.
Example
Wireless is going to drive up your cost-per-sensor and is not without its
problems. ·What about Dallas 1-Wire? ·The BS2p can ·use any pin to
communicate with 1-Wire devices, like the DS1820 temperature sensor. ·Dallas
also makes a 1-Wire digital switch. ·This would let you do remote control
over that same bus.[/font]
Cheers
Chris
--- In basicstamps@y..., jonwms@a... wrote:
> In a message dated 3/1/01 8:23:48 AM Central Standard Time,
> Christopher_Hill@M... writes:
related
converted to
that
> > transmitters.
> > Example
Room
> > Must be cheap <
without its
> problems. What about Dallas 1-Wire? The BS2p can use any pin to
sensor. Dallas
> also makes a 1-Wire digital switch. This would let you do remote
control
> over that same bus.
