Driving a relay
I'm trying to drive a relay using the stamp, and i've got a PN2222A
transistor that i'm using due to the current limitations of the
stamp, but for some reason when i turn it on, the relay doesnt
activate.
Here's how i have it hooked up:
Use (for example) a 1K resistor between the stamp pin and the base of
a 2N2222 transistor. The emitter of the transistor goes to ground.
The light bulb goes from +V to the collector.
Transistor Emitter - VSS
Transistor Base - Pin 0
Transistor Collector - Pin 1 of Relay
Relay Pin 1 = Collector
Relay Pin 2 = Vin
I know the relay works, so shouldnt this circuit work?
activate.
Relay Pin 2 = Vin
1) What's the voltage and current rating on the relay coil?
2) Have you included a snubbing diode across the relay coil to prevent a
voltage spike to the Stamp when the magnetic field collapses?
3) Where did the light bulb come from?
In a message dated 02/27/2001 9:24:04 PM, immolation@h... writes:
>activate.
>Relay Pin 2 = Vin
>Thanks
Larry Geib
ljgeib@a...
the lightbuilb line was copied from a faq that i was basing it on
The relay is a 5v relay, that i can turn on by connectin the Vin + VSS
directly, but i know about the current limitations so i dont wanna run it
without a transister.
To: <immolation@h...>; <basicstamps@yahoogroups.com>
Sent: Tuesday, February 27, 2001 9:33 PM
Subject: Re: [noparse][[/noparse]basicstamps] Driving a relay
a few things to think about:
>activate.
>Relay Pin 2 = Vin
>Thanks
Larry Geib
ljgeib@a...
collector & emitter on the 2n2222 reversed
In a message dated 02/27/2001 10:58:52 PM, immolation@h... writes:
>Doh
>it
>From: <LJGeib@a...>
>a
>>activate.
>>Relay Pin 2 = Vin
>>Thanks
Larry Geib
ljgeib@a...
You could either measure it directly with a meter, or measure the resistance
and R=5V/ohms. From that info we can tell you if the 2222 can drive it.
With 1K in the base, the 2222 can safely drive up to about 75 ma. The
previous diode advice is absolutely necessary, or you will smoke the
transistor.
Ray McArthur
My relay's:
5 VDC DPST - N.O.
Mfg. - GUARDIAN
Mfg. # 1665S-2A-5D
1-1/8" x 1/2" x 1"
5 amp @ 30 VDC/120 VAC
Coil resistance: 45 ohm
Thanks for the help
--- In basicstamps@y..., "Ray McArthur" <rjmca@u...> wrote:
> If we know the current drain of the relay, we can probably help you
out.
resistance
drive it.
The
> transistor.
> Regards,
> Ray McArthur
+ VSS
wanna run it
resistor to 470-510 ohms. The diode can be almost anything like a 1N914
type sold by Radio Shack, a 1N4148, or even a higher current type you may
have around. Connect the diode across the relay coil with the band
(cathode) on the power supply side of the coil. If this doesn't work, try
another 2222, since the first one may have been damaged by running without a
diode.
Good luck,
Ray McArthur
> Hmm, what kind of diode should i use, and how should i hook it up?
> My relay's:
> 5 VDC DPST - N.O.
> Mfg. - GUARDIAN
> Mfg. # 1665S-2A-5D
> 1-1/8" x 1/2" x 1"
ordered 30 PN2222A online, radio shack is too expensive for lots of
stuff
thanks for help, i'll post again if i have problems
one more question, because of the 16 port limit, i'm limited
obviously to how many relays i can drive, is there an add on IC that
i can control that will allow me to individually turn on/off relays
via some method?
Thanks again
> Your relay should draw ~5v/45 ohm=111ma. For good turn-on, reduce
the base
1N914
you may
work, try
without a
> diode.
> Good luck,
> Ray McArthur
> From: <immolation@h...>
> > My relay's:
> > 5 VDC DPST - N.O.
> > Mfg. - GUARDIAN
> > Mfg. # 1665S-2A-5D
> > 1-1/8" x 1/2" x 1"
·········I I've found that the easiest way to drive relays is to use a relay
driver like the ULN 2803 it only cost . 50 cents from mouser Electronics.
Using the 2803 you would connect pin 0 to pin(1) 0f the 2803 ·and pin(18) ·to
the coil of the relay and the other end of the coil goes to V+. When Pin(0)
goes High Pin(18) goes Low which cause the relay to latch.[/font]
1) Since the Basic Stamp FAQ was mentioned, I wanted to point out that just
below the passage quoted is this text:
-- begin quote
Don't use this to power an AC lamp! There you'll want to use a relay (easy
and safe) or some sort of AC switching device like an SCR. If you use a
relay, you can wire the coil like the lamp, but be sure to put a diode
across the coil with the banded end towards the power, and the non-banded
end towards the collector of the transistor. This prevents fast changes in
the coil current from generating large voltages that can fry the transistor.
-- end quote
Maybe I should explicitly say "If you use a relay (for AC or DC
switching)..." On rereading this, I see where you might think it only
applies if you are switching AC. Of course, doesn't matter what you are
switching -- the coil operates the same way.
2) If you want to expand the number of I/O pins on the Stamp, check out the
PAK-III and PAK-IV. Also, the PAK-I and PAK-II do floating point math and
have 8 or 16 extra I/O pins for your program.
Al Williams
AWC
* Expand your Stamp I/O: http://www.al-williams.com/awce/pak3.htm
> From: immolation@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oMjin7wOfiW0a7u7izU24Ilw31ETcu4wD-Z3jO7DzgwpJBqRz-lfzc2eMP5Ni93GiW109uKkZ2FX7XuRdQw]immolation@h...[/url
give you enough current to drive the relay. Try changing the resistor first
and it may work.
At 07:02 AM 2/28/01 -0000, you wrote:
>Gotcha, i probably cooked the first two transistors i tried then, i
>stuff
>via some method?
>Thanks again
>the base
>1N914
>you may
>work, try
>without a
>> diode.
>> Good luck,
>> Ray McArthur
>> > My relay's:
>> > 5 VDC DPST - N.O.
>> > Mfg. - GUARDIAN
>> > Mfg. # 1665S-2A-5D
>> > 1-1/8" x 1/2" x 1"
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Larry G. Nelson Sr.
mailto:L.Nelson@i...
http://www.ultranet.com/~nr
Can you help me understand how you came to the 470-510 ohm recommendation?
For some reason transistors are so foreign to me. I can usually make the
circuit (simple switching) work, but don't really know what values I should
be using, now how to select an appropriate transistor for the load I wish to
drive, etc.
-- Mitch
From: Ray McArthur [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=balX1tq3w_Gqt3tARmDJLrUS5GLY2OfpH-PvGm6iMFh0byEfUH3FANix9k-MkeuCjEZgqv9xsIbbMsU]rjmca@u...[/url
Sent: Wednesday, February 28, 2001 12:58 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Driving a relay
Your relay should draw ~5v/45 ohm=111ma. For good turn-on, reduce the base
diode.
Good luck,
Ray McArthur
> My relay's:
> 5 VDC DPST - N.O.
> Mfg. - GUARDIAN
> Mfg. # 1665S-2A-5D
> 1-1/8" x 1/2" x 1"
opto-isolator to separate our logic-level stuff from the AC stuff. This was
for safety as well as legal reasons.
Our equipment uses 110 volt relays, so we use an opto-isolator to drive a
triac, which drives the relay coil. A similar circuit could be used for the
Basic Stamp stuff.
> A few thing relevant to this thread:
just
> -- begin quote
transistor.
> -- end quote
the
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
The Al Williams post is a good answer. I can summarize the way we arrived
at ~470 ohms for the base drive. Since the relay would draw 111 ma from the
5V supply, we know the 2N2222 collector current=111ma. Bipolar transistors
"amplify" the current into their base. This current gain is called hfe, or
beta. So to get 111 ma collector current, we must drive the base with
111ma/hfe. What is hfe for the 2222? If you look at the gain curves, it
varies from hundreds to less than 10, depending on collector volts and amps.
For use as a switch, we want to turn it on hard so as to drop little voltage
across the transistor, and provide full voltage to the load. This also
keeps the 2222 cool since transistor power dissipation is collector-emitter
volts*collector amps. The gain curves indicate a gain of 10 to 20 when the
2222 is turned on hard, (like 0.1 Volts collector). So, 111ma/10 =11.1 ma
needed for the base. The base-emitter looks like a diode, so it will rise
to ~0.7 volts when the Stamp pin goes high. Stamp pin output is almost 5
volts, so, (5v-0.7v)=4.3 volts across the base resistor. Since we need 11.1
ma base current, Rbase=4.3v/11.1ma=387 ohms. Doing the same assuming hfe of
20 yields 774 ohms for Rbase. The 470 to 510 ohms is an in-between range
that should work. You can assume this "forced beta" value of 10-20 for most
small high-gain transistors used as a switch.
Ray McArthur
should
to
> drive, etc.
> -- Mitch
base
a
> diode.
<<< snip >>>.
Say you have a 50 ohm load between 5V and the collector. Further, say you
deliver 1mA into the base (as Ray described) and the Beta is 50. With 1mA
in, and Beta=50, the collector current should be 50mA.
So if the R is 50 and I is .05, you have a voltage drop of 2.5V. Since the
supply is 5V, the collector voltage must also be 2.5V. If the base current
were 500uA (.5mA) then the collector current would be 25mA and the voltage
across the load would be (50x.025) 1.25V. Therefore, the collector must be
at 5-1.25= 3.75V.
However, what if you increase the base current to 2mA? Now the Ic=100mA and
the voltage across the load has to be 5V. That means the collector must be
at 0V. The problem is, the transistor can't get to 0V -- .1V would be good
and .2V is probably more realistic. So before you get to this point, the
simple model we all use for the transistor quits working. Ic <> B*Ib (in
English, Collector current DOES NOT equal Beta times base current).
Crank that base current up some more! 3mA, now the calculation says the
current has to be 150mA, but it can't be and it isn't. That would require
7.5V across the load or -2.5V on the collector. I'm assuming the emitter is
grounded in all of these cases.
So the reality is that once the collector reaches about .2V or so, it is all
over and we call that point saturation. As the name implies, adding more
(base current) when you are saturated doesn't really make any difference.
So for switching you'd like to go into saturation, and you want some safety
margin, but you usually don't want to overdrive it unnecessarily. So when
you hear the term saturation, now you know what it means.
If the analysis seems confusing check out
http://www.al-williams.com/wd5gnr/basiccir.htm
Good luck!
Al Williams
AWC
* 8 channels of PWM: http://www.al-williams.com/awce/pak5.htm
> From: Ray McArthur [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KLGTARr3UY4y3s31Y1SoDf-H0nZhD-QuyOQ4sYdtDoCX-G6eKRzFC71b2hXeOIHGbr9_GSkHoUwX5G4Y]rjmca@u...[/url
> Sent: Wednesday, February 28, 2001 3:00 PM
keep it simple.
Ray McArthur
Sent: Wednesday, February 28, 2001 5:02 PM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Driving a relay
and
safety
specs. from many manufacturers, but where do I go to find specs on a
run-of-the-mill 2n2222? I don't want to spend $8 just to get a $0.10
transistor that has specs.<g> Using known resistances, and voltages, can
you effectively measure beta? Ie: If I use the example Al gave (his Voltage
amplifier example), can I measure the Vce, knowing Ib, Rb and Rc and do some
calculations to approximate beta (sufficiently enough for basic switching
usage ... most of what I do is switching ... at least for now).
Mitch
From: Ray McArthur [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZDDN87X3wy1VCNv-QXsn3ABEXupQ-1ybC8Fqe-0rOFu9QHelDTpyOGikbDgHUXq-QuTwxVaHhCDu6NgfOQ]rjmca@u...[/url
Sent: Wednesday, February 28, 2001 8:18 PM
Very good, Al. That is why I used the term "forced beta", but decided to
keep it simple.
Ray McArthur
and
safety
them (that 2N2222 is a JEDEC number which stands for something, but I don't
know what).
However, let me point out yet one more thing. Beta is a bad design
parameter. That's one reason you want a margin on your saturation. Beta
varies wildly based on process variation (manufacturing), temperature, and
other factors.
For example, if you decided you wanted to build an audio amplifier, the
right way to do it would NOT be to just use the circuit we've been talking
about and use the Beta calculations. Instead, you provide biasing so that --
as long as Beta is over some low number -- your gain is set by resistors.
This results in less gain, but greater stability. Thermal runaway is
particularly nasty since higher temperatures increase beta, which increases
gain, which increases temperature, which increases beta.... that's why the
call it runaway.
Now none of this has to do with switching, so you are fine. I just didn't
want to give anyone the wrong idea.
I could go on about how to design a normal amplifier, but I won't -- it is
sort of OT. Maybe an article for my site if I can find the time.
Here's the Phillips data for a 2N2222A:
http://www-us6.semiconductors.com/pip/2N2222_CNV_2
Al Williams
AWC
> From: M. D. Miller [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YeoWMRXdNFb7wzvHxpPVWWr1r8nfeCSLbutvLMXcp1-c8CjL86ZUBlAv1fijMQfZTrK4wnwExvk]mdmiller2@h...[/url
> Sent: Thursday, March 01, 2001 9:09 AM
> So ... the next question is where to find these specs? I know
> you can find
> (his Voltage
> and do some
> Thanks,
> Mitch
> From: Ray McArthur [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nn3vqMgFFdzFK8wXxeUwTLr-lF23g3zSmJnleUeklEj4Si2wR8VL_3AJkHYW8tfTbTQxBfgnd1ZQlKC8c2dD]rjmca@u...[/url
> keep it simple.
> Regards,
> Ray McArthur
> From: Al Williams <alw@a...>
> and
> collector must be
> would be good
> B*Ib (in
> safety
I'll plan on finishing up my recently-purchased copy of The Art of
Electronics to get these details (when I need them).
Thanks for all your help, Al.
-- Mitch
nr@ma.ultranet.com writes:
and it may work.
try the circuit again but ·use a 390 resistor for RB..... let me know how it
works out[/font]
but a quick search through the back logs of this forum haven't
revealed an answer. I know that to drive a relay with a stamp I need
to run it to a transistor. I am assuming the circuit is the same as
the one in the parallax catalog for running a motor. I have also
heard that a diode is needed in the circuit somewhere. I went out
and bought some 1A rectifier diodes (I am beginning to think that is
the wrong kind) so I could run my 600ma motor. My biggest question
is where do I put the diode? The people I have talked to just say
you need a diode, but not what to connect it to. Thanks for your
time, and if you are going to reply, please do it off-list because I
don't check here often.
The PTT is forced low and will drive most transmitter PTT circuits. If your
transmitter has a relay make sure it has a diode in parallel with the coil.
This prevents reverse voltage spikes from entering the microprocessor. (Fig
1)
About reverse voltage spikes :
Reverse voltage spikes are created when the magnetic field in a coil
collapses. This can be avoided by adding a diode in parallel with all
associated relays as in (fig2). Reverse voltage spikes will cause the
micro-controller to reset and loose its brain. This can damage the IC's in
any electronics application. This is easily avoided so please follow the
simple schematic included.
Both paragraphs taken from RC1P.TXT, and I don't remember where I got them,
and the author didn't sign it.
Jason
Sent: Monday, May 14, 2001 8:58 AM
Subject: [noparse][[/noparse]basicstamps] Driving A Relay
> I know this has been asked more times than anyone wants to answer it,
Sorry, Roger.
Jason
To: <basicstamps@yahoogroups.com>; <yanroy@u...>
Sent: Tuesday, May 15, 2001 2:48 PM
Subject: Re: [noparse][[/noparse]basicstamps] Driving A Relay
> PTT:
your
coil.
(Fig
> 1)
them,
> Jason
> From: <yanroy@u...>
