DC motor speed control signal
I need a tachometer signal to time slow rotations (10-80 deg/sec) of a
4-inch drum driven by a DC motor. Is it realistic to try to print an
alternating black/white stripe sequence on a laser printer, tape it around
the drum, and then to "watch" this sequence with a source/receiver
photodiode to generate a square wave tachometer signal? If so, would
printing on white paper be OK, or is another surface better?
Dennis
Dennis
reflective photosensors at about 3/4 inch and had good results. The ones
I've used have the emitter and sensor mounted at "an optimal angle" in a
plastic body with a mounting slot. I think Digikey has these for a buck
or two each.
On Sun, 25 Feb 2001 20:49:46 -0800 "Dennis P. O'Leary"
<doleary@h...> writes:
> a
> around
> would
> Thanks,
> Dennis
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
>Thanks,
>Dennis
Hi Dennis,
A laminated plastic film _might_ be better from the standpoint of
dimensional stability and water/oil resistance. For inkjet
printing, I swear by the white opaque polyester film from Luminos:
http://www.lumijet.com/Lumijet.htm
best regards,
-- Tracy
couple magnets glued to the inside or outside of the drum. You'll
want to get a PAK-VII from http://www.al-williams.com/awce/ so you
can count the two channels at once. You could count rotations with a
single sensor, but for RPM's, two would be best mounted 90 degrees
apart and measure the time between them.
Hope this helps...
- Brice
of a
an
it around
would
> >Thanks,
> >Dennis
> Hi Dennis,
> best regards,
> -- Tracy
problem requires such slow rotations, less than 1/4 revolution per second,
I'm trying a really simple approach -- operating "open loop" without a tach
signal. I'm using a 12 V geared, DC reversible motor from Jameco which
requires only 45 mA at no load. I need 4 constant velocities, selectable by
4 pins on a Stamp, so the plan is to use 4 open-collector channels of a
ULN2003 driver chip, each with a different valued 1% current-limiting
resistor in series with the motor's ground. The resistor values will
determine the speed to an accuracy of about 1%, and a regulated 12 V supply
will keep everything more or less stable, at least in theory. This does
require 4 stamp pins, each selecting a motor speed, but simplifies
programming and parts count.
I though this approach might also be useful for some slow 'Bot applications,
like arm or head movements.
Dennis
From: Orrin f Drew [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZH8fjfwf1s1lr4FaBcDfwypT4CwOnbJ3oxJWA612IagqDEVnujLh-ZczjLxAx6aUlZqu8HYZ6A]odrew@j...[/url
Sent: Sunday, February 25, 2001 9:27 PM
Subject: Re: [noparse][[/noparse]basicstamps] DC motor speed control signal
Good method, works pretty good especially for slow signals. I've used IR
or two each.
> a
> around
> would
> Thanks,
> Dennis
speeds.
> Thanks to Tracy, Orrin and Brice for good suggestions. Because my drum
tach
by
supply
applications,
> Dennis
> From: Orrin f Drew [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qIp3hyRoUgPFJf5BL94W8KVUJ1LeGc_VBndSmybdeXVHtrO4VN0ZjOnIj4_EFqi49q_2qQ]odrew@j...[/url
> or two each.
> > a
> > around
> > would
> > Thanks,
> > Dennis
