here''s an idea
I have not heard of anything yet but I look forward to being able to use
Linux with my Stamps.
Have you the seen the Samsung YOPY palmPC with Linux yet, that looks like a
good tool, I wonder if I could interface it to my Stamps?
Nick
Sent: Sunday, February 25, 2001 8:46 PM
Subject: Re: [noparse][[/noparse]basicstamps] here's an idea
> I think to make it would would require the compiler used on dos and then a
few
> routines to handle the transfer to the stamp. The rub is will the compiler
be
> available for linux/unix?
> Mike
> Nick Messenger wrote:
> > A Robot on a Linux server what a cracking idea. Tell me more :-)
> > Nick
> > From: "Mike Eggleston" <mikee@m...>
> > Sent: Sunday, February 25, 2001 4:33 PM
> > Subject: [noparse][[/noparse]basicstamps] here's an idea
> > > Since it seems that the stamp can be talked with and programmed
> > > with only three wires, then what about a small 'bot tethered
> > > to a linux server that can be attached to through the 'net.
> > > The 'bot could have some sensor or other, maybe even a camera,
> > > and it could receive instructions from someone attached to
> > > the linux box. The bot could even be reprogrammed, or dynamically
> > > programmed, from the linux box while the bot is out searching the
house.
> > > I think it would be even neater (is that a word?) if it could
> > > be performed through an IR transceiver, but that would be more
> > > complicated than a simple teather.
> > > Mike
> > > Your use of Yahoo! Groups is subject to
Nick
few
be
> Mike
> > Nick
house.
> > > Mike
