bs2sx EEPROM question
hello,
on the BS2SX there are 8 banks of 2k of memory, can you write to say
the 3rd bank of memory (EEPROM) and read it later?
I know i can do this if i just have a one file program...but i am
doing a multiple file program and say for example in the 4th file i
want to write to eeprom and then later on after the data is collected
be able to read the data. can i do this? please help!
Also if i was using the PAK2 how do i store a number like 9.876 into
eeprom easily (it would be already stored in the paks registers 0-
23) I know of the highbyte...lowbyte stuff but when i do that i get a
different number out than what i put in!!!
thanks
steve
thanks
steve
>thanks
>steve
Hi Steve,
The only connection between the banks is the RUN command. Each
bank that you want to use to store data will have to have a short
program installed. Your main program "calls" (RUNs) the appropriate
bank. The program there writes or reads the data to/from eeprom,
using the main RAM or the scratchpad RAM as a temporary holder.
Then that program RUN's back to the original bank to continue
execution. Crossbank calls cannot be made from within subroutines
nor for-next loops.
There are some examples of one approach to crossbank calls at,
http://www.emesys.com/BS2SX.htm#Crossbank
The new BS2P makes this a lot, lot simpler, with the new STORE
command. You can write/read data directly in all 16k from a program
running in any of the 8 banks.
regards,
-- Tracy Allen
http://www.emesystems.com
