Variable Resistor
I am looking for a way to replace the variable resistor in a
wheelchair control joystick. there are two pots in the joystick,
each controlling the motors with a pulse-modulation type circuit. I
need a way to imitate the variable resistors with no physical
connections between the wheelchair circuits and the stamp circuits.
My thought was to use 4 cds cells and small lamps and use the pwm
output of the stamp to vary the brilliance of the lamps. I haven't
tried this yet, but does anyone have another (better) way?
TIA
Doug Simpson
TIA
Doug Simpson
What about the PWM output going to an optoisolator?
Are you wanting to separate the two circuts to prevent motor noise
from entering the BS circut?
the closeness (and strenght) of a magnet which could be mounted on the
control handle.
Good Luck,
Jim
> TIA
> Doug Simpson
LCA-110's
LCB-110's
available from Digi-Key
good luck[/font]
Jim Szymczak
Sent: Thursday, February 22, 2001 8:43 PM
Subject: Re: [noparse][[/noparse]basicstamps] Variable Resistor
[font=arial,helvetica]if you do try the optoisolators check out CP Clare.
LCA-110's
LCB-110's
good luck
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
[/font]
