Help with Senior Design Project
My senior design partner and I are working on building a water
sampler and need some technical advice on using the Basic
Stamp. The water sampler is being designed from a hobby type
electic boat and we have two extra radio control channels to use (4
channel radio). We would like to use a Basic Stamp to control up
to 4 selenoid valves, to turn on a small pump and to wind and
unwind a reel of hose. Any advice you have, even if it is a harsh
reality check, would be very helpful.
Montessa Young and Stephanie Hallock
University of Idaho BioSystems Engineers
I presume the boat motor is electric?
Sounds like you just program a sequence of events - once
the boat is stopped, unroll the hose (use an optical or
mechanical limit switch to get reproducible hose length
deployment). When the limit switch changes state (hose
deployed) start the pump - either for a fixed duration
or for a fixed volume - stop the pump, roll up the hose,
and be on your way. You really only need one input to
change state to start the entire sequence - giving you
one extra radio channel to use for launching torpedos :-)
Just add a servo with a magnet mounted to one arm and a
Hall-Effect switch on a BS input. Not high-tech, but it
should work.
Have fun!
Arlen Fletcher
"They that can give up essential liberty to obtain a
little temporary safety deserve neither liberty nor
safety." - Benjamin Franklin
receiver (instead to use a servo) and have it doing all timing and logic
sequences.
ACJacques
have to clear out the hose of the previous sample? I would think an air
pump to blow it out, or to pump for so long (overboard I hope!) to ensure
that the water in the hose has been flushed out
Sent: Tuesday, February 20, 2001 12:14 PM
Subject: Re: [noparse][[/noparse]basicstamps] Help with Senior Design Project
> What? No GPS system onboard!!??
> should work.
> Have fun!
> Regards,
> Arlen Fletcher
Hallock
Engineers
Check out http://divelec.tripod.com/rcic2/rcic-2.html
for a dedicated PIC that you can connect directly to your RC receiver. It
has 2 digital outputs for each channel (a total of 4). One that goes high
when the joystick is one side of center and one that goes high when it is on
the other side of center. In addition, it has a PWM output that you can use,
after filtering, for a 1 to 3 volt signal that is proportional to the
distance that the joystick is moved from center. It also has LED outputs you
can use to trim your RC channels to center as well as one to indicate
receipt of pulses. It would free up your BS2 to do other things at the same
time.
Carl
Diverse Electronic Services
Sent: Tuesday, February 20, 2001 1:39 PM
Subject: [noparse][[/noparse]basicstamps] Help with Senior Design Project
Engineers
If you haven't received the precise help you need please contact me off list.
If I can control a train I should be able to help control a boat.
Sid Weaver
Newzed@a...
