'Example
lastbytetoclear var word '2047 is last byte, but program will crash
anyway once the routine clears program data.
counter var word
for counter = 0 to lastbytetoclear
write counter, 0
next
end
'regards, Chris
Sent: Tuesday, February 20, 2001 10:13 AM
Subject: [noparse][[/noparse]basicstamps] eeprom
> does anyone know how to clear the eeprom of a bs2 chip?
> thank you for your time..
> ~Rich
You need to initialize the outputs. If you're just using four bits, do this:
DirA = %1111
... or for eight bits:
DirL = %11111111
-- Jon Williams
-- Parallax
In a message dated 4/13/02 10:12:05 PM Central Daylight Time, leroy@f...
writes:
> I am trying to read a four bit value stored in eeprom and place into the
> first 4 or 8 outputs. Any ideas about why the following doesn't work?
> Thanks for your help..
> Leroy
> '{$STAMP BS2}
> 'Write the values to EEPROM.
> CHARACTER var byte
> x var nib
> Data "BetsywasaGoodOlegirl"
> for x = 0 to 20
> READ x, CHARACTER
> outa = CHARACTER
> pause 2000
> outa = 0
> debug bin CHARACTER
> debug " :", dec x
> debug CR
> next
> > x var nib
> > for x = 0 to 20
Also x needs to be a byte if it is to go above 15
>DirA = %1111
>DirL = %11111111
>-- Jon Williams
>-- Parallax
>writes:
> > Leroy
> > '{$STAMP BS2}
> >> CHARACTER var byte
> > x var nib
> > for x = 0 to 20
> > READ x, CHARACTER
> > outa = CHARACTER
> > pause 2000
> > outa = 0
> > debug bin CHARACTER
> > debug " :", dec x
> > debug CR
> > next
And if I wanted to write the values as a hex number I would write what ?
Also the statement: Data "BetsywasaGoodOlegirl" places number patterns
in the eeprom. Could I specify those patters in binary? Also, what is
the size limitataion of the eprom for this type of storage?
thanks so much for help. I am sure these questions are in the manual,
somewhere, I just don't know where they are..
Leroy
Tracy Allen wrote:
> > > x var nib
> > > for x = 0 to 20
> >DirA = %1111
> >DirL = %11111111
> >-- Jon Williams
> >-- Parallax
> >writes:
> > > Leroy
> > > '{$STAMP BS2}
> > >> CHARACTER var byte
> > > x var nib
> > > for x = 0 to 20
> > > READ x, CHARACTER
> > > outa = CHARACTER
> > > pause 2000
> > > outa = 0
> > > debug bin CHARACTER
> > > debug " :", dec x
> > > debug CR
> > > next
>So if I write:
>'for x = 1 to 20'
>the compiler assumes decimal, not hex?
Yes, it is always decimal, unless you specify $20 for hex.
x has to be defined as a byte in either case, because a nib can only
hold values up to 15, $0f.
Any of the following puts exactly the same numeric values in memory:
Data 66,101,116,115,121,....
Data $43,$65,$74,$73,$79,.. ' represented as hex
Data %01000010,%01100101,%01110100,%01110011,%01111001,... ' binary
They are in the introductory section where it talks about variables,
and also (in the version 2.x manual) in the command reference under
"DATA" (but not under "RTFM"!).
>Leroy
>Tracy Allen wrote:
> > > > x var nib
> > > > for x = 0 to 20
>bits, do this:
> > >DirA = %1111
> > >DirL = %11111111
> > >-- Jon Williams
> > >-- Parallax
>leroy@f...
> > >writes:
>place into the
> > > > Leroy
> > > > '{$STAMP BS2}
> > > >> CHARACTER var byte
> > > > x var nib
> > > > for x = 0 to 20
> > > > READ x, CHARACTER
> > > > outa = CHARACTER
> > > > pause 2000
> > > > outa = 0
> > > > debug bin CHARACTER
> > > > debug " :", dec x
> > > > debug CR
> > > > next
>Subject and Body of the message will be ignored.
has anyone actually downloaded enough times to the eeprom on the basic
stamp to make it stop working? the manual says its like 10e6 or something
bwahahaha...?
counter var word
write counter, 0
next
end
'regards, Chris
> ~Rich
FREE! The World's Best Email Address @email.com
Reserve your name now at http://www.email.com
Leroy
'{$STAMP BS2}
CHARACTER var byte
x var nib
for x = 0 to 20
READ x, CHARACTER
outa = CHARACTER
pause 2000
outa = 0
debug bin CHARACTER
debug " :", dec x
debug CR
next
DirA = %1111
DirL = %11111111
-- Jon Williams
-- Parallax
writes:
> Leroy
> '{$STAMP BS2}
> CHARACTER var byte
> x var nib
> for x = 0 to 20
> READ x, CHARACTER
> outa = CHARACTER
> pause 2000
> outa = 0
> debug bin CHARACTER
> debug " :", dec x
> debug CR
> next
> > for x = 0 to 20
>DirA = %1111
>DirL = %11111111
>-- Jon Williams
>-- Parallax
>writes:
> > Leroy
> > '{$STAMP BS2}
> >> CHARACTER var byte
> > x var nib
> > for x = 0 to 20
> > READ x, CHARACTER
> > outa = CHARACTER
> > pause 2000
> > outa = 0
> > debug bin CHARACTER
> > debug " :", dec x
> > debug CR
> > next
'for x = 1 to 20'
Leroy
Tracy Allen wrote:
> > > x var nib
> > > for x = 0 to 20
> >DirA = %1111
> >DirL = %11111111
> >-- Jon Williams
> >-- Parallax
> >writes:
> > > Leroy
> > > '{$STAMP BS2}
> > >> CHARACTER var byte
> > > x var nib
> > > for x = 0 to 20
> > > READ x, CHARACTER
> > > outa = CHARACTER
> > > pause 2000
> > > outa = 0
> > > debug bin CHARACTER
> > > debug " :", dec x
> > > debug CR
> > > next
>'for x = 1 to 20'
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
>Leroy
>Tracy Allen wrote:
> > > > x var nib
> > > > for x = 0 to 20
>bits, do this:
> > >DirA = %1111
> > >DirL = %11111111
> > >-- Jon Williams
> > >-- Parallax
>leroy@f...
> > >writes:
>place into the
> > > > Leroy
> > > > '{$STAMP BS2}
> > > >> CHARACTER var byte
> > > > x var nib
> > > > for x = 0 to 20
> > > > READ x, CHARACTER
> > > > outa = CHARACTER
> > > > pause 2000
> > > > outa = 0
> > > > debug bin CHARACTER
> > > > debug " :", dec x
> > > > debug CR
> > > > next
bwahahaha...?
