PCB exposure
I just received my first batch of positive acting presensitized PCB, and
on the package it says "exposing time only eight minutes under fluorescent
light" does this mean I have to set up my transparency in the dark? Will an
incandescent bulb expose the film? I was under the impression that I needed
a special UV exposure bulb, but this package sounds like any old Fluorescent
will do.
Jeff
will do.
Jeff
You may use a standard desktop flourescent lamp, with the lens removed. I
use an F15 model, placed 3 inches above my circuit. I expose for 20 minutes.
The Pre-sensitized board gives times also.
You need not worry about normal room light, while placing your board, and
getting things ready, they dont expose that fast in room light. I do turn
off direct overhead lamps, just to be safe. Dont peal off the plastic film
layer until you are actually ready to develop it. In my room, I have a
single Incandescent lamp that is about 5 feet away from where my circuit is
to be developed and I never had any premature exposures.
Good luck
>will do.
>Jeff
Sincerely
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
from Kepro. The boards are exposed to UV from a lamp for 60 seconds.
Paul
> From: Jeff Mitchell [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2Bf_p7ietKRLzCMw_eEtT8GLKgIll12DVdQ9NeFxKjUFSm1U327sGd9-Ltz_Hywb8v-zJKyjQaCMudHjEA]EL-JEFE@P...[/url
> Sent: Monday, February 19, 2001 8:49 AM
> Subject: [noparse][[/noparse]basicstamps] PCB exposure
> under fluorescent
> dark? Will an
> old Fluorescent
> will do.
> Jeff
