Hall Effect Sensor
Need pin out (connection) for a hall effect sensor that
I purchased from JameCo.
Part number is a HI-300, not for sure that I have it
hooked up correctly..
Does anyone have a good site to reference this part??
You might email Jameco's tech support. They used to have data sheets
listed by their part number on sight, but now looks like they just have
obsolete sheets in ftp area.
Allegro has info on theirs at their site, I don't know if the pinout is an
industry standard.
This might be a lesson learned..
Sent: Thursday, February 15, 2001 5:48 PM
Subject: [noparse][[/noparse]basicstamps] Re: Hall Effect Sensor
that
it
part??
have data sheets
like they just have
> industry standard.
download the data sheet from there Manufacture pin out may just be the same
Im looking for my sheets but digi key is going to be your best bet.
> industry standard.
other items I'm going to get also..
On Thu, 15 Feb 2001 16:58:53 -0800, L .Gaminde wrote:
>Go to Digi key site they have hall effect sensors from there you can
>the same
>>sheets
>>have
>>pinout is an
>> industry standard.
If this is anything like the H-301 that Jameco used to carry
(made by Cosmo), the pinout is (with silk-screen facing you):
VCC ···ground ···output
Don't hold me to that, though. If you can't get a definitive answer,
give the above a shot. Worst thing that will happen is you'll blow $0.75.
Cheers,
Steve
[/font]
they may need to be turned off once turned on ) the ones I used were not
latching so they counted a passing magnet without needing resetting, with
these you may need two magnet's one north pole one south pole
PicProgrammer@a... wrote:
> Gene,
> VCC ground output
> Cheers,
> Steve
this what you may have used??
On Thu, 15 Feb 2001 18:03:29 -0800, L .Gaminde wrote:
>One other point the hall effect sensors in the jameco cat are
>latched (
>not
>with
>> Gene,
>> VCC ground output
>>answer,
>>$0.75.
>> Cheers,
>> Steve
Gene Shults wrote:
> I'm looking at difikey also and looking at the Unipolor switching. Is
> >latched (
> >not
> >with
> >> Gene,
> >> VCC ground output
> >>answer,
> >>$0.75.
> >> Cheers,
> >> Steve
