Interpolation/linearization
I am trying to use the Basic 2 stamp to perform curve fitting of a
non-linear function.
I am generating an analog voltage proportional to a measurement that
will have 40 steps. This voltage is then fed into either a 8 bit or
12 bit A/D. I then intend to use the PWM function to then generate a
0 to 5 volt linearized output.
The output range of the A/D is 78 to 116 or 1261 to 1858, depending
on the A/D used. I have thought about using the lookup and lookdown
function. The problem is that if the 8 bit A/D is used, due to
rounding errors I will obtain 2 bit patterns. If I use the 12 Bit A/D
the lookup/lookdown will exceed the 255-element size.
I think interpolation is the way to go. But due to the non-linear
function I have not been able to my routine to work. Has any one
written a routine that I may be able to use?
Please any help is appreciated.
John
John
Maybe the following URL would help. Look at "tables and interpolation"
http://www.emesystems.com/BS2math3.htm
- Tracy
Thanks for your input.
My question with your routine is how can you make it
work when the width of the catagories 'K' is not
evenly spaced, as in your example.
John
--- Tracy Allen <tracy@e...> wrote:
> Hi John,
> and interpolation"
> - Tracy
__________________________________________________
Do You Yahoo!?
Get personalized email addresses from Yahoo! Mail - only $35
a year! http://personal.mail.yahoo.com/
>> > Hi John,
>> > and interpolation"
>> > - Tracy
Interpolation is best done with the READ command, using data you have
stored as DATA using two tables, breakpoints for the input and
output. It is possible to do it using LOOKDOWN and LOOKUP,but I have
found that implementation using those commands will eat up a lot, lot
more memory. You need to do this with the 12-bit ADC, or else there
will be no grist for the interpolation. The following example uses
just 5 points, purely random values on my part. You would want more
breakpoints.
Xtable DATA word 1261, word 1356, word 1555, word 1781, word 1858
Ytable DATA 0, 37, 145, 195, 255
' note entries in Xtable are the input breakpoints
' for PWM breakpoints to output in the Ytable
Ntries DATA 4 ' number of table entries minus 1
X var word ' input data 12 bits from ADC
X0 var word ' breakpoints in Xtable
X1 var word
Y0 var byte ' breakpoints in Ytable
Y1 var byte
Z var byte ' interpolated value for PWM
i var byte ' index for table lookup
loop:
gosub getX ' get X data 12 bits, not shown
X = X min 1261 max 1858 ' clamp the X value
X0=1261 ' initial value for interpolation
for i=1 to Ntries
' need two reads to get a word variable:
read Xtable+(i*2),X1,byte0
read Xtable+(i*2)+1,X1,byte1
if X<=X1 then foundcatagory
X0=X1
next
foundcatagory:
' now read the corresponding Y values (bytes for PWM):
read Ytable+i-1,Y0
read Ytable+i,Y1
' interpolate:
Z= (Y1-Y0)*(X-X0)/(X1-X0)+Y0
PWM 0,Z,255 ' make PWM on P0
goto loop
There is probably a typo or error in there somewhere, but I think
that is pretty close. It is important that the product
(Y1-Y0)*(X-X0) has to be less than 65536. That is not a problem
here, but it is a caveat depending on the input and output data
requirements.
I hope that helps,
-- Tracy Allen
Thanks for you help.
John
> it
> >> > Hi John,
> "tables
> >> > and interpolation"
> >> > - Tracy
> curve fitting of a
> a measurement that
> either a 8 bit or
> to then generate a
> to 1858, depending
> lookup and lookdown
> used, due to
> size.
> to the non-linear
> work. Has any one
> using data you have
> input and
> LOOKUP,but I have
> eat up a lot, lot
> ADC, or else there
> would want more
> breakpoints.
> 195, 255
> breakpoints
> 1
> X1 var word
> Y1 var byte
> loop:
> for i=1 to Ntries
> X0=X1
> next
> foundcatagory:
> for PWM):
> read Ytable+i-1,Y0
> read Ytable+i,Y1
> ' interpolate:
> goto loop
> product
> not a problem
> output data
> requirements.
> I hope that helps,
> -- Tracy Allen
Do You Yahoo!?
