Advice
I am hooking up a Hal effect sensor to a motor to
monitor the rpm's.
What I am getting is a square wave that is 13 volts as
expected but I am also getting a
1 volt sine wave ontop of the square. Will the stamp
see this and affect my counting??
Should I run this signal though a opamp to clean it
up??
And will the stamp be able to handle the 13 volt
pulse??
Gene
monitor the rpm's.
up??
pulse??
Gene
Not sure, but doubt that the Stamp will handle the 13 volt signal and suggest
you limit input to stamp to its supply voltage. Also suggest you square up
the signal from Hall effect sensor with opamp configured as Schmidt trigger
to get rid of any noise on signal and then use diodes tied to ground and plus
supply at the input to Stamp and 10K ohm resistor between op amp output and
Stamp. This will limit the voltage excursion to Stamp to supply plus 0.6
volts and ground minus 0.6 volts.
Good Luck, Burt
amps...
Sent: Monday, February 12, 2001 11:20 PM
Subject: Re: [noparse][[/noparse]basicstamps] Advice
> Hi Gene,
> Good Luck, Burt
Date: Tue, 13 Feb 2001 00:20:12 EST
This looks like the answer to a question that I've been asking myself about how
to safely use 12-14V or so as a trigger for a PIC. My initial thoughts were on
the lines of a zener diode or an optoisolater.
I can't quite see how one would connect the two diodes in the scheme that
you've outlined though?
Regards, Derryck
/ The Cheshunt Computer Club /
/ The essential for your Atari /
/ Monthly meetings /
/ http://www.cix.co.uk/~derryck /
>monitor the rpm's.
The 1 volt sine wave will have no effect on the Stamp, because it is
well above the Stamp switching threshold. A voltage divider (22k/10k
or 22k/4.7 volt zener) could bring the 13 volts safely down to the 5
volt level of the Stamp.
>up??
The CD4050 is a CMOS chip that does bring a signal from the higher
voltage (13 volts) down to 5 volts, and clean it up in the process.
Another alternative, could you run the hall effect sensor off of a 5
volt supply instead of off the 12v battery? The op-amp would be
overkill and still requires extra parts.
>pulse??
see above,
-- good luck
Tracy Allen
http://www.emesystems.com
with no problems, Where are you getting your power and is it filtered
real good or not, you may look at running off the stamp's 5vdc supply
> >monitor the rpm's.
> >up??
> >pulse??
> see above,
> -- good luck
> Tracy Allen
pulse is looking better.
I will try it up to the stamp now.
Still have the 1 volt riding on top of the square wave,
this won't be a problem?
Sent: Tuesday, February 13, 2001 10:35 AM
> I have used the hall effect sensor with 5 vdc and 15
feet from the stamp
and is it filtered
stamp's 5vdc supply
> > >monitor the rpm's.
volts as
stamp
it
> > >up??
from the higher
in the process.
sensor off of a 5
op-amp would be
> > >pulse??
> > see above,
> > -- good luck
> > Tracy Allen
>> and 15 feet from the stamp with no problems,
>> filtered real good or not, you may look at
The 1 volt sine wave is probably pickup from nearby wiring. Is the
sine wave at 60hz, or some other frequency? If the hall effect
switch has a pullup resistor, you could reduce the pickup by lowering
the resistor value, say, from 10k down to 1k. To minimize pickup,
use a shielded cable, even so far as to include the sensor inside the
shield.
That said, the 1 volt sine wave on top of the 5 volt square wave
should not be a problem. It would be above the switching threshold
of the Stamp, which is at 1.4 volts.
-- Tracy
