inverse trig functions
Currently I am working on a project to simulate sunrise and sunset for a
given date and geographical coordinates using a STAMP 2. My main source of
problems is that most of the algorithms available require inverse trig
functions(atan, asin, acos) to work properly. The only way I can think of
implementing them is to have a table of values stored for every possible
angle, but I don't really want to use that much space.
I would appreciate any feedback you could give me in this regaurd. If
someone has the source code for computing inverse trig functions or has
made a similiar program to compute daylight hours on a stamp, I would love
to see it.
May the Force of God be with you,
Kevin Womack
___,
,____
__--~~~~ ~~---,_
,-' __,--,_ `\,___,-,__
,-' __/'/-~~~\ ` ` . ' , | `~~\
_/` _/~~ '~~ \,_\_ O / ' '~_/' `\
/' ' =-'~~ _ / ~ /' `\
_/' /~ ,--,____,
|,_,-,_ `\
_,/' ' ,-' _ `~'
,-' /~ ' ,-~~~ _, ,-=~~~~~~~~~~~~'| |
/' ,/' _/~'
, / /` _/~ "But those who hope in the
/~ / /` /'Lord will renew their strength.
.' /' They will soar on wings like
/' . /' eagles; they will run and not grow
` /' | weary, they will walk and not be
' faint." - Isaiah 40:31
to see it.
Kevin Womack
___,
,____
__--~~~~ ~~---,_
_/' /~ ,--,____,
|,_,-,_ `\
_,/' ' ,-' _ `~'
/' ,/' _/~'
between table entries
make use of symmetry - should get useful results with only 40 or 50 table
entries
richard
Sent: Monday, February 12, 2001 9:46 AM
Subject: [noparse][[/noparse]basicstamps] inverse trig functions
of
> to see it.
> Kevin Womack
> ___,
,____
> __--~~~~ ~~---,_
> _/' /~ ,--,____,
|,_,-,_
> _,/' ' ,-' _ `~'
> /' ,/' _/~'
the
strength.
grow
floating point, check out our PAK-II --
http://www.al-williams.com/awce/pak1.htm (page for PAK1 and PAK2, but the
PAK2 is the one with trig).
Al Williams
AWC
> From: Kevin Womack [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IWSqXjhk1OfKhotBqwTK1LLkr-BkXVQgB6ROobvjPfux20zt2zl3dTTPbdEV2kz1D8nFOhZyDBxZGhId]jedi@m...[/url
> Sent: Monday, February 12, 2001 9:47 AM
> source of
> to see it.
> Kevin Womack
> ___,
,____
> __--~~~~ ~~---,_
> _/' /~
> ,--,____,
|,_,-,_ `\
> _,/' ' ,-' _ `~'
> ,-' /~ ' ,-~~~ _,
> /' ,/' _/~'
> hope in the
> their strength.
> and not grow
As the others said, a table with interpolation is the quick and easy
way, but there are other methods. The way in which computers (BS2 or
your desktop PC) compute complex functions like sin, arcsin, etc., is
through an approximation method known as finite Taylor series
polynomials. To any desired degree of precision, there is a
polynomial function (i.e., f(x) = a + bx + c x^2 + d x^3) that is
guaranteed to be within whatever your accuracy limit is of sin(x).
This is likely to also be true for arcsin, arctan, etc., although I
don't remember off the top of my head and I would need to do the math
to check it out. If you feel that this is for some reason neccessary
for your application, write back and I'll help you through the math.
-Doug McClean
jxm156@p... or IDiggles@a...
(woohoo, I finally get to _answer_ a question on this group, I knew
it would happen eventually...)
for a
source of
trig
think of
possible
If
has
would love
> to see it.
> Kevin Womack
> ___,
,____
> __--~~~~ ~~---,_
> _/` _/~~ '~~ \,_\_
O / ' '~_/' `\
> /' ' =-'~~ _ /
> _/' /~ ,--,____,
|,_,-
,_ `\
> _,/' ' ,-' _ `~'
> /' ,/' _/~'
hope in the
strength.
wings like
and not grow
not be
