SerIn SerOut w/TWS434 RWS434
Has anyone ever used the TWS/RWS 434 to do RF communication with the BS2?
I'm not sure if I know what I am doing.
I only have 1 BS2 and 1 breadboard. I am trying to connect both the TWS and
RWS to the same stamp.
Shouldn't I need a resistor for the pin(s) that goes to the ground?
Can you use 1 BS2 stamp to test TX and RX to yourself or would this create a
timing problem trying to TX and then RX in the same code?
Example code would be much appreciated.
Wayne Fulcher
wayne@d...
Wayne Fulcher
wayne@d...
