hardware not found error
i'm having some trouble with my stamp. it keeps saying hardware not found
when i'm trying to test the program. i have the scott edwards book with the
cd and i'm running the stamp2.exe from the cd, but i keep getting the error
message, hardware not found.
i've got a working nine volt battery and the plug going into the COM port of
my computer and i don't understand why it isn't working...
any suggestions...???
- LaQuida
>===== Original Message From basicstamps@yahoogroups.com =====
>I use PicBasic, if that makes any difference [noparse]:)[/noparse] Thanks for your help so
>far... I haven't had a chance to try programming the chip as an F84 instead
>of F84A.
>______________________________________________
>FREE Personalized Email at Mail.com
>Sign up at http://www.mail.com/?sr=signup
- LaQuida
>of F84A.
'{$Stamp BS2}
debug "hello world"
Alt-R to run and i keep getting hardware not found error
and i'm still getting the error message, i don't know what's wrong
how can i tell if my stamp is damaged?
is there anything else i can type in as well to test this??
>Did you use the STAMP Directive by putting the following line as the first
>line of your program?
>'{$Stamp BS2}
>If you are using a different stamp, change the type to reflect that. See
>the BASIC Stamp Programming Manual 2.0c, Page 35 for more information.
>Hope this helps...
>- Brice
>From: sunset97 <sunset97@s...>
>To: <basicstamps@yahoogroups.com>
>Sent: Saturday, February 10, 2001 5:50 PM
>Subject: [noparse][[/noparse]basicstamps] hardware not found error
>- LaQuida
'{$Stamp BS2}
Hope this helps...
- Brice
- LaQuida
>of F84A.
8.1v. the voltage regulator needs a voltage overhead to work properly. It
usually happens right after I've just added some exotic (for me) new circuit.
That's when I figure I fried the stamp. Now I check the Battery level with a
DVM before I start gnashing and wailing.
I hope this is the problem for you--
In a message dated 2/10/01 5:56:12 PM, sunset97@S... writes:
>the
>error
>of
>>- LaQuida
Larry Geib
ljgeib@a...
be good and i tried it with another one that was at 8.9v so it's not the
battery level..
any other suggestions...?
- LaQuida
>Try a fresh Battery- I get the same message when my 9v dips bellow about
>>the
>>error
>>of
>>>- LaQuida
>Larry Geib
>ljgeib@a...
- Brice
Sent: Sunday, February 11, 2001 12:08 PM
thanks but i tried that already... the battery was at 8.7V so it should
still
battery level..
- LaQuida
circuit.
a
>>the
>>error
>>of
>>>- LaQuida
>Larry Geib
>ljgeib@a...
my lab top so it'll be steady....
how can i tell if my COM port setting is correct or not?
>Did you ever have it working? Your COM port settings might be incorrect.
>- Brice
>still
>battery level..
>- LaQuida
>circuit.
>a
>>>the
>>>error
>>>of
>>>- LaQuida
>>Larry Geib
>>ljgeib@a...
·····I had the same problem with a Basic stamp..... I did find out what was
causing the problem it was the computer. I guess the com port was not
configure correctly... I had the same problem with three other computers with
was two PIII and one Celeron 550 laptop.... ··I still have the problem I had
to go back to useing my ole computer which is a PII-450...
wendell ·[/font]
