H-Bridge (was Digest Number 467) link to schematic
Check this link for a schematic.
http://www.cs.uwa.edu.au/~mafm/robot/blanch-h-bridge.html
hope this helps.
ps:
I like to read the previous note/comment on the same thread, so it's
fine with me to get a very long, multi comment message. As Al has
said, I REALLY prefer all new topics to be accurate. There are
bunches of threads that are just 'help' or 'newbe question' And I
try to add a comment if my reply is a reference like a link. It
makes it really really easy to go back and find a link in a bunch of
replys.
Dave
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> Probably the best write up on a H-bridge I know of is at
www.bobblick.com --
> I can't get his site up right now, or I'd give you the exact link.
> Parallax sells the MotorMind B which is an easy way to get all this
working
> with very little fuss.
> Can't tell from your note, but an H-Bridge is only necessary when
you want
> to reverse the direction of the motor. If you just want to drive a
motor in
> one direction and use a higher/different voltage than the Stamp,
just use a
> power MOSFET or an L239 or similar switching device.
> On a list-related note, I am personally very bad about not clipping
original
> messages when I reply to the list. I tend to just leave the whole
thing as
> it was, which I know some people find objectionable. However, if
you get the
> digest version, you might want to consider cutting the reply text
since it
> has all the messages you are replying to. Changing the subject line
is good
> too.
> Good luck!
> Al Williams
> AWC
> * Floating point math for the Stamp, PIC, SX, or any
microcontroller:
> http://www.al-williams.com/awce/pak1.htm
> > From: scott stewart [noparse][[/noparse]mailto:hercules_62215@y...]
> > Sent: Thursday, February 08, 2001 11:05 AM
> > To: basicstamps@y...
> > Subject: Re: [noparse][[/noparse]basicstamps] Digest Number 467
> > ARRRRRGHGGGGG!
> > can anyone point me to a site or tell me how to get my
> > stamp to turn on an H-Bridge. I want to run some hobby
> > motors with separate power separate batterys and want
> > my stamp battery to be isolated so that i can monitor
> > it...........bear in mind that i'm a 'mechanical'
> > engineer. Thanks much in advance.... :]
hope this helps.
ps:
replys.
Dave
www.bobblick.com --
working
you want
motor in
just use a
original
thing as
you get the
since it
is good
> too.
> Good luck!
> Al Williams
> AWC
microcontroller:
> > ARRRRRGHGGGGG!
