H-Bridge (was Digest Number 467)
Probably the best write up on a H-bridge I know of is at www.bobblick.com --
I can't get his site up right now, or I'd give you the exact link.
Parallax sells the MotorMind B which is an easy way to get all this working
with very little fuss.
Can't tell from your note, but an H-Bridge is only necessary when you want
to reverse the direction of the motor. If you just want to drive a motor in
one direction and use a higher/different voltage than the Stamp, just use a
power MOSFET or an L239 or similar switching device.
On a list-related note, I am personally very bad about not clipping original
messages when I reply to the list. I tend to just leave the whole thing as
it was, which I know some people find objectionable. However, if you get the
digest version, you might want to consider cutting the reply text since it
has all the messages you are replying to. Changing the subject line is good
too.
Good luck!
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
> From: scott stewart [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xKbmfoWcHffrfPxsr5BqaLvEsV7Faunld8uYV-LUpelityX-ktgb8EGXmPATJZ7n48LqGEXZE4uWjhPqvA0]hercules_62215@y...[/url
> Sent: Thursday, February 08, 2001 11:05 AM
> Subject: Re: [noparse][[/noparse]basicstamps] Digest Number 467
> ARRRRRGHGGGGG!
> can anyone point me to a site or tell me how to get my
> stamp to turn on an H-Bridge. I want to run some hobby
> motors with separate power separate batterys and want
> my stamp battery to be isolated so that i can monitor
> it...........bear in mind that i'm a 'mechanical'
> engineer. Thanks much in advance.... :]
too.
Good luck!
Al Williams
AWC
> ARRRRRGHGGGGG!
www.bobblick.com --
working
you want
motor in
just use a
original
thing as
you get the
since it
is good
> too.
> Good luck!
> Al Williams
> AWC
microcontroller:
> > From: scott stewart [noparse][[/noparse]mailto:hercules_62215@y...]
> > To: basicstamps@y...
> > ARRRRRGHGGGGG!
www.bobblick.com --
working
you want
motor in
just use a
original
thing as
you get the
since it
is good
> too.
> Good luck!
> Al Williams
> AWC
microcontroller:
> > ARRRRRGHGGGGG!
www.bobblick.com --
working
you want
motor in
just use a
original
thing as
you get the
since it
is good
> too.
> Good luck!
> Al Williams
> AWC
microcontroller:
> > ARRRRRGHGGGGG!
