Liquid Cooled PCs (was: Liquid Resistor)
I work with a guy who build a liquid cooling system for his PC. Attached a
block of aluminum to a peltier junction and fastened it to his processor
(don't remember if he was using Intel or AMD). Then ran cooling liquid (ie:
water) through the aluminum block using an aquarium pump and tank. Seems
like he was running a processor rated 550 Mhz at something over 800Mhz.
Never had the guts to try it myself ... I'd just as soon stick with the
mfr's specs. <g>
-- Mitch
From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YfVBv9PVjg06EfmsUdYjtN3mJUCBCnxeTPPNcdsZKxSHN-LYyfMJrFlr0Ldn4zc716hyQlf9qMYo4p12Q4U]alw@a...[/url
Sent: Thursday, February 08, 2001 10:34 AM
Subject: RE: [noparse][[/noparse]basicstamps] Liquid Resistor
Just for the record, I don't liquid cool my PC. That was someone else
(Staph).
I have, however, cooled power resistors.
Al Williams
AWC
* One day left to save on PAK-I and PAK-IV: http://www.al-williams.com/awce
> From: Cy Brown [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KzSgyVoPvdLUMJ7P-gHnLAdaEA1nm-4rrR86wg7tVIGdjm3OQgHEXy5uQ6a2tIC_LyZP0Aw07ogOX7c]bushman@t...[/url
> Sent: Thursday, February 08, 2001 10:46 AM
> Subject: Re: [noparse][[/noparse]basicstamps] Liquid Resistor
> Yes, I want to be able to immerse my circuitry in liquid as if it where in
> air. Mineral oil seems to be the quick answer but will Im worrid about
> corrosion also. My project is similar to Al Williams but I want
> to see if I
> can immerse the whole machine in liquid. The idea is as much for
> the looks
> as it is for cooling. 3M Fluorinert may be the way to go, Ill
> just have to
> save up for it.
> Cy Brown
> From: Ray McArthur <rjmca@u...>
> To: <basicstamps@yahoogroups.com>
> Sent: Thursday, February 08, 2001 12:44 AM
> Cy:
> What do you mean by insulator? Non-conductive cooling fluid,
> high breakdown
> voltage, low dielectric constant?
> Ray McArthur
> From: Cy Brown <bushman@t...>
> Sent: Thursday, February 08, 2001 12:00 AM
> Subject: [noparse][[/noparse]basicstamps] Liquid Resistor
> > Where can I find a liquid that is a very good insulator? As good or
> better
> > than air.
mfr's specs. <g>
-- Mitch
(Staph).
Al Williams
AWC
> to see if I
> the looks
> just have to
> save up for it.
> Cy Brown
> Cy:
> high breakdown
> Ray McArthur
> better
> > than air.
http://www.cyberbound.net/overclock and let me know what you think.
I've got a spare waterblock and I've thought about water-cooling my
BS2SX but it doens't seem to get hot enough to really benifit. :-)
Anyone have any tips on overclocking a BASIC Stamp? Maybe I could
run a water-cooled BS2SX at 100MHz?
Water cooling a PC is very inexpensive and does a MUCH better job
than air cooling. Just be careful and make sure you tighten all the
hose clamps. I've been running it for a couple months now and no
leaks at all.
By the way, I use the PAK-IV coprocessor from Al Williams (
http://www.al-williams.com/awce/index.htm ) and I HIGHLY recommend
it. He's got them on sale until tomorrow and EVERYONE on this list
needs to get one! I wouldn't start any Stamp project without one.
- Brice
Attached a
processor
liquid (ie:
Seems
800Mhz.
the
> mfr's specs. <g>
> -- Mitch
> From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9R8VSsmo8-Fp7ZmmNqhx-bU9ZKlRg6FSAlO37RzmTqNt3cc_knIjsWuYD5NUj8cR5ysy-S_CQZO00A]alw@a...[/url
else
> (Staph).
> Al Williams
> AWC
williams.com/awce
> > From: Cy Brown [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OcwaehVQpIxVaZEKurmvVD2tZt9jWrUEn7YXcq2JmoD5vaHjCxEpNVbsYHqJVDGzk0KC7TlrIFY6Cw0]bushman@t...[/url
where in
about
> > to see if I
> > the looks
> > just have to
> > save up for it.
> > Cy Brown
> > Cy:
> > high breakdown
> > Ray McArthur
good or
> > better
> > > than air.
Pop3Now Personal, Manage 5 Email Accounts From 1 Secure Window
Sign Up Today! Visit http://www.pop3now.com/personal
