Math Question
Jeff-
Something like this ought to work:
hex_out DATA $00,$20,$7D,$FE
READ hex_out + (time_var + 1 / 400), speed
where time_var holds the result of the RCTIME operation.
Steve
On 8 Feb 01 at 22:06, Jeff Mitchell wrote:
> I would like to convert a variable that ranges between 400 and 1800
> dec. into 4 proportional hex numbers. (0,20,7D,FE)
> I.E. if rctime returns a variable of >400 and <800 then output hex0
> if >800
> and <1200 then hex20 etc..
Steve
> if >800
> hex_out Data $00, $20,$7d,$fe
> read hex_out + (500 +1/400), speed 'the result with a
> variable
> of 500 will be 1.25. will the .25 be ignored?
Correct. All division on the Stamp yields integer results.
> Why do you have the equation written as (time_var +1 / 400) instead
> of
> (time_var / 400) ?
It was meant to fit your "if rctime returns a variable of >400 and
<800 then output hex0 if >800 and <1200 then hex20 etc.." criteria.
It yields $00 for 0 <= time_var < 399, $20 for 399 <= time_var <
799 and so on. Looking at it again, it could stand some
improvement. If the difference between (for example) 398 and 399 has
little significance in your application, I'd go with the simpler
(time_var / 400), or modify the expression to slide the break-off
points one way or the other (careful not to generate some negative
intermediate or final results).
Steve
I.E. if rctime returns a variable of >400 and <800 then output hex0 if >800
Right now I have a bunch of if then statements that say if variable is
between 400 and 800 then speed1. 800 to 1200 goto speed2 etc. There must be
a simpler way to modify the variable. I would like to save code and just say
If variable is greater than 0 goto speed: and let speed use the variable to
figure out what hex number to send.
Any suggestions?
Jeff.
>Steve
Thanks Steve!
So if my time_var is say 500, the read command will only go to the "1"
location and disregard everything after
the decimal ?
read hex_out + (500 +1/400), speed 'the result with a variable
Why do you have the equation written as (time_var +1 / 400) instead of
(time_var / 400) ?
I'm going to use my digital weigh scale indicator to monitor the weight of
packages.The weight of package is 5 digits for example,"08275" displayed as
08.275 Kg with decimal point.There are several thousand of packages and I
want to get their sum of weight in ton at the end of the day,for
example,"52742" which will be displayed as 52.742 Ton.
How can I compute this with the stamp closer to correct result?
Thank You
Mohamed Refky
_________________________________________________________________
The new MSN 8: smart spam protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
wrote:
> Hello,
weight of
displayed as
and I
> Thank You
> Mohamed Refky
Hi Mohamed,
not to answer your question, but how did you plan on making sure no
one weighed the same package twice ?
seems a bar-code scan would be very advnatagous.
won't the basic running
weight=running weight+package
keep a running track ?
if running weight is greater than 2,000 (I'm thinking pounds here)
tons is greater than 2,000 then tons=tons+1 and
running weight=running weight - 2000 you just subtract 2000 pounds
(1,000 kilos?) from the running weight as you add a one to the tons.
that way you keep track of tons and the remaining weight is held
at the end of the day, all you need do is to either display the
remaining kilos or convert the remaining weight to fractions of a ton.
or, you could show tons as one value and the remainder in kilos. so
your output could be 52 tons, 742 kilos
> packages.
Do you have a digital weigh scale module connected up to your BS2?
Do you know what model etc it is?
Of all the modules i've seen, I not spotted a weight module...
Cheers
Kev/.
jim
http://www.geocities.com/jimforkin2003/
From: Mohamed REFKY [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JZ9VtVPqCTfoMyHCnTF-Zms5-zESAX1Zlx5KZ8S-UVJHDllQyjULzYiDP10-qBkYXcEAa70Rzw]refky@h...[/url
Sent: Tuesday, May 13, 2003 3:51 PM
Subject: [noparse][[/noparse]basicstamps] Math question
Hello,
Thank You
Mohamed Refky
>Thank You
>Mohamed Refky
Are you using the Pelouze scale that is available from McMaster Carr?
8.275 is stored in the stamp as 8275, then several thousand packages
could add up to 8275000 or more, too much for 16 bits. One metric
ton is 1000 kilos, which would be 1000000 in this scheme, also larger
than 16 bits. The total weight might be something like 8.275111
metric tons, if you carry it out to full precision.
One approach would be to carry to a second word when the total weight
exceeds 10 kilos (10000 in the Stamp):
allWeight0=allweight0+thisWeight
allWeight1=allWeight0/10000 + allWeight1 ' carry to high word
allWeight0=allWeight0//10000 ' low word stays < 10000
debug dec dec allWeight1/100,".",dec2 allWeight1,dec4 allWeight0
' displays running total
' 3 places left of the decimal, 6 to right of decimal.
That could record up to 655.350000 metric tons, 655350.000 kilos.
Another approach would be to use double precision binary. The carry
occurs not at 10000 but at 65536:
thisWeight var word ' one package
allWeight0 var word ' low word of running total
allWeight1 var word ' high word of running total
addWeights: ' Z=X+Y in 16:16 notation
allWeight0 = allweight0 + thisWeight
if allWeight0<thisWeight then allWeight1=allWeight1+1 ' carry (pbasic 2.5)
Then at the end of the day, you have to kick out that double
precision bianry number as decimal digits to your display. A
subroutine to do that is described on my web site at:
http://www.emesystems.com/BS2math6.htm#showdubdec
The routine would have to insert the decimal point 6 positions from
the right to get the answer in metric tons.
weigh scale indicator with 2 setpoints using the Basic Stamp.I use the
MAX7219 to drive 5 digits led display.
I have a project using this indicator (Liquid Filler) posted in the customer
applications section on Parallax web site.
Thank You
Mohamed Refky
>From: Tracy Allen <tracy@e...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] Math question
>Date: Wed, 14 May 2003 08:06:00 -0700
> >Hello,
>of
>as
> >Thank You
> >Mohamed Refky
>2.5)
Add photos to your messages with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
