Cat detector/RFID tags
Can't seem to find who started this question, but here is a possible solution:
What may do the job is a RFID tag (radio frequency identification). This
technology is finding it's way into many areas, including retail, industrial,
medical, inventory control and tracking and many others.
At the recent Front Line show I attended (formally known as Scan Tech) in the
Chicago area, several systems were demonstrated and I believe that one of
more "kits" were available. The RFID tag is powered from an external source
and contains an antenna (loop), active device (usually some sort of receiver,
of very low power consumption) and low power transmitter. The RFID tag
typically has a code embedded in it that is sent back to a receiver that can
be used to open the door into the "cat house".
I believe that the transmitter operates at a frequency of 13.xxx Mhz and is
crystal controlled. RFID tags can be about the size of a credit card or
smaller with the outer area used for the loop antenna. The Mobil gas "Speed
Pass" uses RFID technology (I believe). But for your application, size and
weight are important (for the cat) and other frequencies may be better and/or
offer other advantages.
Get out the grid dip meter, determine the resonant frequency of the speed
pass, determine the embedded code and go to it!
Your comments, thoughts and ideas please. Burt
("Speed Pass") idea.... The Speed Pass used by Mobil Oil is pretty
small and would easily fit on a cat collar.
They (the Mobil Oil people) also told me the little embedded battery
is expected to last for "several" years...
Just be prepared to answer questions when you start waving your cat
in front of the gas pump. :-)
Cheers,
Don
possible solution:
industrial,
Tech) in the
one of
external source
receiver,
tag
that can
Mhz and is
card or
gas "Speed
size and
better and/or
speed
