Sonar
Can anyone tell me how to take the 'distance' reading that the Polariod 6500
generates to the stamp, and tell the stamp to move that 'distance'. I can
quite easily programme each individually but I can't figure out from the
Stamp manual how to use the reading I get from my sonar board, and tell the
motors to either move that distance or stop, depending how close it is to an
object.
Many, many thanks in advance to anyone who is able to solve this problem,
which I've been trying to solve for months.
John
object.
John
and tell the stamp to sstop the motors if the distance measurement is
below a certain number. ('m working on my own robot with the same
setup but I don't have a 6500. I'm building my own sonar based on
the diagram in the stamp manual).
Doug
> To: <basicstamps@yahoogroups.com>
> From: "john & lisa" <johnlisa@c...>
> Date: Sun, 28 Jan 2001 14:25:04 -0000
> Reply-to: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Sonar
> object.
John
Do you have shaft encoders for exact readings on the wheels to
measure distance? If not, you will have to use time/distance type
data.
Find out how far it moves in a second, then find out how far away
something is and do some math.
Say the distance measuring system says it's 5 feet to the object.
Your bot can move 6 inches per second. it will take 10 seconds to
reach the object. The rangefinder returns a number of some sort, that
will be a close proportion to the distance it is from an object.
We'll use 5ms for each inch of distance. 5 feet is 60 inches. 60
inches times 5 ms =300 ms for a 5 foot distance. Lets say your
polaroid returns a number of 300 (to make it ieasy to do the math)
for this distance. the stamp reads 300 from the polaroid, and tells
the motors to run for 6 seconds. (300ms/5ms) if it were half that
distance it would be 150ms (150/5ms)and the stamp would
do the math to get a time/distance of 5 seconds or 30 inches.
Hope this helps, and keep in mind that these numbers are purely
theoretical.
Doug
> object.
John
I know this is a little OT, but I would like to build my own ultrasonic
distance sensor controlled by a BS2SX, but I'm having trouble finding
transducers. Does anyone know good transducers and where to get them?
Thanks in advance,
Rik
haven't done anything with them yet so can't report on their functioning!
Bree
>===== Original Message From "Rik Vlaming" <rik.vlaming@s...> =====
>Hello,
>Thanks in advance,
>Rik
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Jameco sells a nice set of matched Transmitter/Receiver 40 kHz
transducers. Part number 136653 for $5.95. Scott Edwards uses them
for the Short-Range sonar project in the book "Programming and
Customizing the Basic Stamp Computer."
--Jeff
High-TechGarage
--- In basicstamps@y..., "Rik Vlaming" <rik.vlaming@s...> wrote:
> Hello,
ultrasonic
finding
them?
> Thanks in advance,
> Rik
from eBay for $5.00 and up, and with a tad of modification they work
GREAT! Mine measure and return (with the right software)
measurements in inches from 20 up to 130 ot 140 or so inches. I have
the Lynxmotion IRPD kit and two sonar modules being debugged and
getting ready to install on my 'bot. The sonar will detect objects
beyond the reach of the infrared, and will detect glass doors
(infrared passes through them and the bot tries to do the same. . .)
I have the software so that either the sonar or infrared will cause
obstacle avoidance and if the 'bot squares up on a wall, the infrared
will stop it, back-up-a-tad-rotate-a-tad-to-the-right and then
coninue on. Detection on one side or the other will cause the motor
on the opposite side to stop, making the 'bor "veer" away from the
obstacle.
Been FUN trying to make the sonar and infrared work together! Timing
is *KEY*
Doug
> From: bs2web@y...
> Date: Mon, 19 Mar 2001 19:48:48 -0000
> Subject: [noparse][[/noparse]basicstamps] Re: Sonar
> Rik,
> --Jeff
> High-TechGarage
> > Hello,
> ultrasonic
> finding
> them?
> > Thanks in advance,
> > Rik
My friend and I got the circuit to work - but we want it to have a longer
range ( about 10 inches right now). Does anyone have any ideas as to how we
can make the circuit have a longer range ? We would like to get a range of
2 to 3 feet. Nothing against the Polaroid sensor, we just want to use the
parts we have ( i.e. the Jameco 136653 40kHz ultrasonic recv/xmit ).
purchased three polaroid sonar 660 sonar cameras and the most I
have paid for ny of them is $7.00. These units work very well for
measuring from about 21 inches to well over 10 feet!. And with a
bit of math, you can measure to 1 inch resolution, full range.
Doug
On 29 Aug 2001, at 8:49, Bryan Smith wrote:
> Has anyone ever tried the Sonar project in Scott Edwards book?
> longer range ( about 10 inches right now). Does anyone have any ideas
> as to how we can make the circuit have a longer range ? We would like
> to get a range of 2 to 3 feet. Nothing against the Polaroid sensor,
> we just want to use the parts we have ( i.e. the Jameco 136653 40kHz
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
Do you have a good source for the polaroid sensors? Thanks in advance.
John
--- In basicstamps@y..., veewee77@a... wrote:
> The sensor set you mention in the Jameco catalog is $6.25. I have
> Doug
ideas
like
sensor,
40kHz
> > basicstamps-unsubscribe@y...
Subject
polaroid 660
polaroid sonar
polaroid autofocus
Don't give more than $10 or $15 shipping included.
Once you get a 660 (or 600 may work) I can give you the scoop on
connecting it and give you software to drive it.
I can also show you how to hack the sonar to make it work.
On 3 Sep 2001, at 15:22, coondog45@h... wrote:
> Doug,
> John --- In basicstamps@y..., veewee77@a... wrote: > The sensor set
> you mention in the Jameco catalog is $6.25. I have > purchased three
> polaroid sonar 660 sonar cameras and the most I > have paid for ny of
> them is $7.00. These units work very well for > measuring from about
> 21 inches to well over 10 feet!. And with a > bit of math, you can
> measure to 1 inch resolution, full range. > > Doug > > > On 29 Aug
> 2001, at 8:49, Bryan Smith wrote: > > > Has anyone ever tried the
> Sonar project in Scott Edwards book? > > > > My friend and I got the
> circuit to work - but we want it to have a > > longer range ( about 10
> inches right now). Does anyone have any ideas > > as to how we can
> make the circuit have a longer range ? We would like > > to get a
> range of 2 to 3 feet. Nothing against the Polaroid sensor, > > we
> just want to use the parts we have ( i.e. the Jameco 136653 40kHz > >
> ultrasonic recv/xmit ). > > > > > > > > To UNSUBSCRIBE, just send mail
> to: > > basicstamps-unsubscribe@y... > > from the same email address
> that you subscribed. Text in the Subject > > and Body of the message
> will be ignored. > > > > > > Your use of Yahoo! Groups is subject to >
> > http://docs.yahoo.com/info/terms/ > > > >
stated in my e-mail, I want to use what I have. Have you ever tried the
Sonar project in the Scott Edwards book ? If so, were you able to make that
circuit extend its range ?
I appreciate your reply, and eventually I probably will experiment with the
polaroid unit - but not yet.
> From: veewee77@a... [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_ba0e323hF_qjnfrROng_zK4fnuTel4ZCMQlB_nwNDgBICNOdjhiSRdp28NBZoJxG2y7eF8bGvNXISz5cA]veewee77@a...[/url
> Sent: Saturday, September 01, 2001 12:31 PM
> Subject: Re: [noparse][[/noparse]basicstamps] SONAR
> Doug
Devantech unit, there are schematics available on the 'net to use them.
Unfortunately I don't have any links on this computer, but if I remember
right, it was easy to search for with Yahoo.
> I've seen a lot of e-mails that reference the polaroid unit. But as I
that
