Relay''s
Go to http://www.ktmarketing.com/CNC.html and select the 5th link from the
top titled "Parallel Port Hookup to Controller". At the bottom of that page
you will find an explaination and a diagram on how to use a transistor ( a
2N2222 will work fine) to drive a relay. Don't forget to get a diode also or
you will likely pop the transistor. Just replace the term PC and Printer
port with Stamp.
Tim
[noparse][[/noparse]Denver, CO]
> From: immolation@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WIErd7Ar2El_I-drFQl-t7jKZE3oITqxUVg97sxJuj4GczJnCOH8c8N-QM73XQJzvMn5ixSe7tR2Mg]immolation@h...[/url
> Sent: Saturday, January 27, 2001 8:30 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Relay's
> Ok, i know absolutely nothing about transistors
I'll go pick some
> up tomorrow though, is there a specific rating that i should get? And
> am i correct in assuming that i just put them in series with the
> relay and the stamp?
> Thanks
> --- In basicstamps@y..., "Mark Hillier" <Mark@H...> wrote:
> > > Hmm, i was planning on just hooking the relay directly into the
> pins. The
> > > relays that i have are marked on the side: 0.6A 125VAC 2A 80VDC
> 0.6A
> > > 110VDC
> > These are the *contact* ratings; they have nothing to do with the
> > voltage or current required to operate the coil.
> > > so looks like there is no way the stamp will put out enough for
> this,
> > > whats the alternative for hooking these up?
> > You will need to drive a transistor with the Stamp pin and have the
> > transistor drive the relay coil.
> > Mark Hillier, VE6HVW
> > President, HVW Technologies Inc.
> > Canadian Distributors of Parallax Products and other Neat Stuff
> > Tel: +403-730-8603 Fax: +403-730-8903
> > See our NEW BASIC Stamp Prototyping tools !
> > http://www.hvwtech.com/stampstack.htm
port with Stamp.
Tim
> Thanks
> pins. The
> 0.6A
> > > 110VDC
> this,
