Relay''s
--- In basicstamps@y..., "Mark Hillier" <Mark@H...> wrote:
> > I've only just started playing around with this stuff and i'm
> > confused about how to hook up a 12v relay, its got 8 pins, 2 of
which are
> > seperated from the rest, i was able to pull up the schematics
online but i
> > have no idea how to hook this up. If required i can take a pic of
it and
> > post it.
> 2 pins at one end are the coil (you can measure a resistance
> between them). The other 6 are contacts and can vary in
> arrangement. Often, the middle set are the common pole and one
> side is Normall Open (NO) and the other is Normally Closed (NC).
> When you energize the coil, the relay will pull-in the contacts and
> the NC contacts will open and the NO contact will close.
> Please note that the MAX current for a Stamp pin is 20 mA source,
> 25 mA sink and most relays (even the small ones) can easily
> exceed that. In other words do NOT connect the coil of the relay
> directly to a Stamp pin. You should also use a protection diode
> (reverse-polarized) across the coil to prevent sureges from
> damaging the Stamp pin when the magnetic field in the coil
> collapses.
> Mark Hillier, VE6HVW
> President, HVW Technologies Inc.
> Canadian Distributors of Parallax Products and other Neat Stuff
> Tel: +403-730-8603 Fax: +403-730-8903
> See our NEW BASIC Stamp Prototyping tools !
> http://www.hvwtech.com/stampstack.htm
Hmm, i was planning on just hooking the relay directly into the pins.
The relays that i have are marked on the side:
0.6A 125VAC
2A 80VDC
0.6A 110VDC
so looks like there is no way the stamp will put out enough for this,
whats the alternative for hooking these up?
which are
online but i
it and
> > post it.
> collapses.
0.6A 125VAC
2A 80VDC
0.6A 110VDC
