Relay''s
Hi relay,
with 8 pins your relay could be a DPCO (double pole change
over) but then again it might be a SPCO (single pole change over) bear in
mind also that a least two of the pins will be for fastening ( to a circuit
board ?)and therefore NC (not connected) Best thing is to identify the
relay's coil contacts first. Use a multimeter, or else take two flying leads
from a 12v supply. The 12v will give you a audible "click" when the two coil
contacts are located. They will be opposite each other. Now the other 4
contacts should be easy to suss out if you again use a meter or else another
pair of flying leads from another battery supply with an LED or bulb in
series. When the coil is activated you will get a light! (or vice-versa)
Happy switching!
To: <basicstamps@egroups.com>
Sent: Friday, January 26, 2001 4:58 AM
Subject: [noparse][[/noparse]basicstamps] Relay's
> I've only just started playing around with this stuff and i'm
> confused about how to hook up a 12v relay, its got 8 pins, 2 of which
> are seperated from the rest, i was able to pull up the schematics
> online but i have no idea how to hook this up. If required i can take
> a pic of it and post it.
> Anyone able to help?
> Thanks
Happy switching!
> Thanks
