RCTime
I saw some instructions on a way to setup multiple push switches onto
one pin in the 1.9 manual and i'm trying to figure out basically how
to do it with a basic stamp and RCTime instead of Pot, but i'm
completely stumped.
Anyone able to just show me how i should be wiring this up and how i
should be coding it?
completely stumped.
>completely stumped.
You can use a very similar circuit (referring to stamp I app note 18
"one pin, many switches"), modified as follows (6 switches shown):
<TT>
10k 10k 10k 10k 10k
+5 Vdd --o-/\/\-o-/\/\-o-/\/\-o-/\/\-o-/\/\-;
N.O. switches % 0 % 1 % 2 % 3 % 4 % 5
stamp P0 -/\/\-o
o
o
o
o
o
1k |
=== 0.01uF mylar film
Vss
</TT>
With one switch at a time down, the time required to charge the
capacitor from zero volts up to the BS2 switching threshold at 1.3
volts is about:
tm = 30E-6 * k second, where k is the switch index.
That is, switch 0 takes zero time, switch 1 takes 30 microseconds,
switch 2 60 microseconds ... switch 5 takes 150 microseconds.
(This comes from solving, 1.3=5*(1 - exp(tm/k*RC))
The value returned by RCtime will be in units of 2 microseconds, or
about 15 units per switch.
' example program for BS2 "one pin, many switches"
tm var word
low 0
loop:
RCtime 0,0,tm ' get time
low 0
debug dec tm,tab,dec tm+7/15 ' show time and key number
pause 200
goto loop
The constants "7" and "15" may need to be adjusted too match the
spacing of tm values you see in your circuit, which will depend on
component tolerances.
Is that what you are looking for?
Be aware that this circuit will not allow you to sort out two or more
switches pressed at the same time. It would be possible to do that,
a different circuit.
Have fun,
-- Tracy Allen
http://www.emesystems.com
capactior and mylar film?
Also, the main reason i'm trying to get this working completely is i
need to run a keypad (about 8 buttons) off 1 or 2 pins, as i'm going
to be using all the rest, is there a simpler method to doing all of
this? (An IC or something i can hook up that will handle the
keypresses?)
Thanks for the help.
onto
how
> >completely stumped.
18
> <TT>
> 10k 10k 10k 10k 10k
> stamp P0 -/\/\-o
o
o
o
o
o
> 1k |
> Vss
> </TT>
> volts is about:
> tm var word
> low 0
> loop:
> low 0
> pause 200
> goto loop
more
that,
> Have fun,
> -- Tracy Allen
Accuracy and stability. A plastic film capacitor (mylar is just one
type) will be within 5% or 2% of the 0.01uF value. And the value
won't change too much with the temperature outside. The ceramic
capacitors are worse (except COG/NPO, which are uncommon in the 0.01
uF value).
>keypresses?)
Follow this link:
http://www.rentron.com/Ser-Key.htm
Bruce has a nice keypad chip that handles up to 10 keys. You will
still need extra parts. The chip requires a crystal, a capacitor,
and a handful of resistors.
When a circuit calls for several resistors of one value, you can
often get them all in one SIP or DIP package. That would go for
either the series 10k resistors called for by the RCtime circuit, or
the pullup resistors called for by the Ser-Key circuit. That saves
on your parts count and hassle. An RCtime circuit with 5 switches
would require one 10kx5 resistor network, one 0.01uf capacitor, and
one 1kohm resistor, plus the 5 switches.
Revisiting the RCtime program, I put in a couple of minor changes, and,
---If no key is pressed, then the RCtime value will be exactly zero,
whereas if any key is pressed, then the RCtime value will be greater
than 0. . The program below loops until a key is actually pressed.
tm var word
k1 con 15 ' RCtime difference, switch to switch
k2 con k1/2 ' half the above for offset
low 0
loop:
low 0
if tm=0 then loop ' tm is exactly zero if no key pressed
debug dec tm,tab,dec tm+k2/k1,cr ' show time and key number
pause 200
goto loop
---It is possible that the user might press the key exactly in the
middle of the RCtime command, and that would give a bogus result. If
it matters, it would be best to read the RCtime value twice in a row,
and only accept a key if the two values agree.
You're welcome!
-- Tracy Allen
>onto
>how
> > >completely stumped.
>18
> > <TT>
> > 10k 10k 10k 10k 10k
> > stamp P0 -/\/\-o
o
o
o
o
o
> > 1k |
> > Vss
> > </TT>
> > volts is about:
>or
> > tm var word
> > low 0
> > loop:
> > low 0
> > pause 200
> > goto loop
>more
>that,
> > Have fun,
> > -- Tracy Allen
information, like how much time it takes for the cap to discharge. All the
program
gives me is result = 1.
considerable detail on the mechanics and mathematics of RCTIME,
specifically pages 257 and 258.
-- Jon Williams
-- Dallas Office
From: MP1428@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PeZ4bgfJhzqV8o__4q_VCeKe3UbRRqzjlcjM6-JiMmH7TXPI466mlbP_v4gPyFe9w51sPZQI]MP1428@a...[/url
Sent: Friday, October 10, 2003 6:16 PM
Subject: [noparse][[/noparse]basicstamps] RCTIME
Has anyone tried the RCTIME example in the manual? Where's the useful
the program
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
