diodes
Archiver
Stampers,
Are there such things as "current-limiting" diodes?
Thanks in advance,
David Fixemer
Thanks in advance,
David Fixemer
Hi David,
Yes, but they are really JFETs (junction field effect transistors)
with the gate connected to the source. The 1N5283 series has
currents available from 0,2 to 5 ma. The voltage across the "diode"
has to be above 1.5 volts (and less than ~100 volts!) in order to
achieve the constant current effect. You can roll your own, using a
JFET and optionally a resistor to trim the current.
-- Tracy Allen
http://www.emesystems.com
I only know of the variety where max forward current rating is exceeded.
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
Yes. They're also called current regulating diodes or constant current
diodes, but they're not widely distributed. The internal construction is
actually a FET with gate tied to source, if memory serves correctly. Here's
a manufacturer link:
http://www.centralsemi.com/cld/index.html
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
CMLHM080
also look in the mouser electronics catalog and they have some ....
LaQuida
>===== Original Message From basicstamps@egroups.com =====
circuits I know is to take an LM317 regulator and
put a resistor from output pin to adjust pin - take
current output from the adjust pin; Vin goes to
input pin [noparse][[/noparse]shunt with .1uf to ground]. The
current out is ~ 1.25/R since the regulator has a
1.25 volt reference internally. Go to National
Semiconductor site and look at LM317 data sheet.
Regulation occurs from about 3.5 to 35 volts -
dissipation on the 317 must be respected and at
higher currents a heat sink is required.
Low end current is limited by the adjust terminal
control current - high current about 1 amp.
I recently saw some current dioded being advertised
to over 700 volts if high voltage is your requirement.
[noparse][[/noparse]I'd have to search ads to find manufacturer].
LM317s come in different packages and max current
ratings; all are cheap...
have fun... premena
Date: Wed, 24 Jan 2001 08:59:15 -0800
Hi David,
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
