Basic Stamp for RS232 baud rate convertor and buffer?
I am not sure whether or not a Stamp is the answer to my problem!· Maybe someone can put me straight?
I have a requirement to connect two pieces of equipment (a test instrument and a fixed baud rate radio modem) via a RS232 connection.· The problem is that the instrument can only communicate at 9600 baud and does not use the control lines (DSR, DTR, RTS and CTS).· The modem can only·communicate at a maximum of 4800 baud, but can accept data at 9600 baud!· The modem only has a 1KB buffer, and thus buffer over-runs occur most of the time.
I need a small unit that will connect to the instrument at 9600, accept incoming data, buffer it (at least 8Kbyte), and play it out at 9600 or 4800, but taking cognisance of the RTS/CTS control lines.
Is this easy and feasable to implement with a Stamp or similar?
Here's hoping - thanks,
Derek Bristow
Derek Bristow
You'll have trouble buffering 8Kbytes with a Stamp.That's just not what it
is meant to do.
You can probably buy something like this off the shelf at www.blackbox.com.
Also I used to work for a company that made something similar many years
ago, but I don't know if they still do. Back then we didn't have a Web site,
but I've heard they are now at www.baytechdcd.com -- their products always
have multiple ports, but they also usually have buffers.
Not 8K, but if you check out the SX University program at www.sxtech.com
you'll find the design for an SSIB which is a SX-based serial buffer for the
Stamp (that is, it works with the Stamp, not that it uses a Stamp). The SSIB
could change baud rates, but it sure doesn't have an 8K buffer.
Good luck!
Al Williams
AWC
* HURRY: January sale is almost over -- see http://www.al-williams.com/awce
for details
From: Derek Bristow [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JL4FBuFqkGTVieMU-bRxoc-zqy13_w5f2IYIVnEdJNVus1zIe8F0d_ejsj8-fs_zf3M2vMbUoR94EwnqfA]derek@i...[/url
Sent: Wednesday, January 24, 2001 1:16 AM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] Fw: Basic Stamp for RS232 baud rate convertor and
buffer?
I am not sure whether or not a Stamp is the answer to my problem! Maybe
and a fixed baud rate radio modem) via a RS232 connection. The problem is
control lines (DSR, DTR, RTS and CTS). The modem can only communicate at a
maximum of 4800 baud, but can accept data at 9600 baud! The modem only has
Derek Bristow
www.rabbitsemiconductor.com/
Mark
Derek Bristow
From: Mark Schmidt [noparse][[/noparse]mailto:mschmidt@gpsgis.com]
Sent: Wednesday, January 24, 2001 9:47 AM
Subject: Re: [noparse][[/noparse]basicstamps] Basic Stamp for RS232 baud rate convertor and buffer?
I'd try the Rabbit 2000.· Although you have to program it in C, they have plenty of examples you can cut and paste from.
Mark
Derek Bristow
