Programming-Variables
I have run into a programming problem. I have too many variables in my
program. I have connected a DS1620 Digital Thermometer, DS1302 clock, matrix
keypad, and LCD to the BSII. I still have two other sensors to add (I am
building a sprinkler system) and have already exceeded 26 variables. The
program I am writing will allow user input from the keypad to set high/low
temps, and five running times with 4 variables for each time, etc. Is there
any way to get around this without adding more EPROM? Could I possibly run
the thermometer portion first to set the variables initially and then
eliminate the unnessecary variables when I integrate the thermometer program
with my main program? I am sending attachments showing the programs we will
be modifying and integrating into our main program. Thank you.
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
thealchemist79@hotmail.com writes:
matrix
program
You may consider storing data in EEPROM (data statements). ·This will allow
you to ·pre-set data using the Stamp's DATA statement. ·Since you're only
dealing with one element at a time, you can read it out of EEPROM, modify it,
then write it back. ·This technique will probably free a bunch of variable
space.
-- Jon Williams
-- Dallas, TX[/font]
Yes. You could setup the 1620 with a separate program ahead of time.
Carl
