Joysticks
On 19 Jan 01 at 20:12, Jeff Mitchell wrote:
> ...I remember a while back, someone posted a list of processor
> times for the various commands. Does anyone have a URL or know
> where I can find that info?
Jeff-
The answer to many of life's questions (including this one) are on
the Good Doctor Tracy Allens's website:
http://www.emesystems.com/BS2speed.htm
Steve
Jeff-
Steve
·In the same train of thought, If I am using pulsout to control a hobby servo, can I substitute a "gosub and return" routine in place of the 20 ms pause between pulsouts? (assuming the gosub command requires roughly the same amount of time to execute)
·I remember a while back, someone posted a list of processor times for the various commands. Does anyone have a URL or know where I can find that info?
Thanks in advance,
Jeff
> Jeff-
> Steve
... and once the newest stamp with it's great new instructions is
released, I'm sure Tracy will be back at it again... Thanks Tracy.
i believe that this not the right group to put this message, but,
since i intend to use it in my stamp project, here goes:
Anyone of you knows where i can buy joysticks (but only the stick
with 2 buttons?) ? i haved tried all, with no success.
any help?
thanks!
http://www.compgeeks.com/details.asp?invtid=SV-200
http://www.compgeeks.com/details.asp?invtid=SV-206
only $1.60 per.
ross
--- "Jo Do <jmsdweb@y...>"
<jmsdweb@y...> wrote:
> hi guys!
> message, but,
> goes:
> only the stick
> success.
> any help?
> thanks!
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
>hi guys!
Happ controls. These are the people who make parts for the arcade game
industry: super tough and reasonable prices. <http://www.happcontrols.com/>
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
>hi guys!
Couple of direct links:
Joysticks page: <http://www.happcontrols.com/joysticks/joysticks_amusement.htm>
2 buttons plus trigger control:
<http://www.happcontrols.com/joysticks/50997000.htm>
dwayne
stamp ll ?
rouww
These old Joysticks will probably have two 100 kOhm logarithmic potmeters
inside. For input into the BS2 you can use the RCTIME command.
To find out which pin in the connector goes to which potmeter you may have
to open the joystick and measure the connections.
Klaus
Sent: Friday, July 16, 2004 8:32 PM
Subject: [noparse][[/noparse]basicstamps] joysticks
> any place to search for schematics on wiring a 9 pin joystick from the
80's to a Basic
> stamp ll ?
> rouww
> Yahoo! Groups Links
the 80's to a Basic
> stamp ll ?
> rouww
You could Google for "atari joystick pinout". I found several hits
doing that, but if memory serves, they were simply a common line
that connected alternately to one of four outer contacts. Two could
conduct if you moved it in a diagonal direction.
Knight Designs
the 80's to a Basic
> stamp ll ?
> rouww
What type of joystick? An Atari joystick simply has 4 microswitches
that are open or closed. Other types of joysticks had 2 potentiometers
(1 for the X axis and 1 for the Y axis).
bit with them.
Basically these are designed with five digital switches and two 8-bit
ADC's. The 5 switches are for the joystick part of it, the two adc's are
for the "paddle" part of it. I actually built a sort of an analog joystick
(star wars style) for the C64 / atari some time in the mid 80's. It worked
okay.
The joystick is an 8-position joystick, so when you're going left, you're
turning on one 'switch', when you're going up, you're turning on another,
when you're going up/left, you're turning on both. All you'd need to do to
read this joystick would be look at the switch states. I think it's just a
matter of grounding the common ground to the pin, which on the BS2 would
just be a matter of building a voltage divider between ground and the
open/closed pin.
Reading the 'paddle' (ADC) part of it might be more tricky, you'd probably
have to use RCtime.
Good luck. Shouldn't be hard.
On Fri, 16 Jul 2004, Chris Savage wrote:
> --- In basicstamps@yahoogroups.com, "fur_princess"
> the 80's to a Basic
> > stamp ll ?
> > rouww
> Chris Savage
> Knight Designs
> from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
> Yahoo! Groups Links
Sean T. Lamont, Director Of Engineering
Innovative Communications Technologies, Inc. http://www.ict.net
email: lamont@a... / sean@i...
"Do not fear mistakes, There Are None" - Miles Davis
