telemetry — Parallax Forums
telemetry
edited 2001-01-26 03:34 in General Discussion
I am a Stamp2 novice. I would like to make a device that would track
a firefighter's location that is going into a large building, and
then have that location monitored by someone outside of the building.
The range would have to be about 300 feet.
I think GPS would not work because the firefighter would be
inside a steel and concrete structure. Altitude is also a factor in a
high rise building.
If constant tracking is not possible, then maybe I would be
looking for something that would help me find a lost firefighter in a
large building. We firefighters now have loud alarms that go off when
still for a certainn length of time. I am looking for something
better than that.
Any ideas would be appreciated.
Thank, Tom Ashe
    edited 2001-01-18 23:04
    Tom,
    Being a firefighter, I know what you mean. The only ways to acomplish this
    could be, me thinks:
    1. Use radio direction finding (RDF). You could provide each man with a
    radio transmitter, which sends bursts at set intervals, with their ID
    number. With two, but preferably three doppler RDF receivers you could
    pinpoint a location quite accurately (in 2D space, if you need to know the
    floor they are on that's harder). The receivers would have to be placed on
    three different sides of the building - maybe mounted on the fire vehicles.
    Even so, mapping the received bearings onto a building's map is somewhat
    difficult, as the receiving station's location relative to the building also
    need to be known.
    2. Use an inertial system, which keeps track of the firefighter's
    acceleration in two or three axis, and determines or estimates distance
    travelled. An application note of this is on Analog Devices' web page
    regarding the ADXL202 accelerometer.
    I've just thought up another one, a kind of reverse-do-it-yourself GPS
    system. If you have three or four transmitters sending out regular pulses,
    it should in theory be easy, provided you have an accurate timebase, to
    calculate the time difference between the signals received at a firefighters
    location, and then send back these timings to a tracking station that does
    all the calculation and triangulation.
    Other than this, yelling into the radio, as it has been done since it's been
    invented, and trusting the alarm...
    All the best,
    Mensaje original
    > De: tashe@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wG8s2zfGPq_KhCvjtX_q2HfhyOsbELtZBanXA4UASTE4dc9yLrGXb8OkAwwpwo6BEWzlUX6RSsFVNcA3]tashe@a...[/url
    > Enviado el: jueves, 18 de enero de 2001 22:22
    > Para: basicstamps@egroups.com
    > Asunto: [noparse][[/noparse]basicstamps] telemetry
    > high rise building.
    > better than that.
    > Thank, Tom Ashe
    edited 2001-01-25 13:48
    There is a company that is completing a device for finding a fireman in a
    building under zero visibility conditions and that has features to help
    find your way out as well as the ability to tag hazadarous materials and
    locate them. New stuff with a PIC as the controller that is in the approval
    stages with the various authorities to become standard approved equipment.
    Much cheaper than thermal imaging cameras and will work in areas that the
    cameras can't plus much more robust.
    >high rise building.
    >better than that.
    >Thank, Tom Ashe
    Larry G. Nelson Sr.
    mailto:L.Nelson@i...
    http://www.ultranet.com/~nr
    Dear Larry,
    Who is the company? Very interested as I have designed a few see through
    smoke devices for fire fighters.
    Please email mocenter@e...
    Mike M
    To: <basicstamps@egroups.com>
    Sent: Thursday, January 25, 2001 8:48 AM
    Subject: Re: [noparse][[/noparse]basicstamps] telemetry
    approval
    > >high rise building.
    > >better than that.
    > >Thank, Tom Ashe
    > Larry G. Nelson Sr.
