It's the "pin-for-pin" part that will get you. The seven device in a
package is kind of unique to the ULN2000 series. These parts seemed to gain
popularity back in the 7 pin dot matrix printer days. You might want to
look at the Allegro parts. They will handle up to 500mA. http://www.allegromicro.com/sf/2003/index.htm
Looks like they may be willing to sample some parts. If not, Newark Elec.
good luck,
At 08:52 PM 1/17/2001 -0500, you wrote:
>Does anyone know of a pin-for-pin direct replacement for the uln 2003
>that can handle more current than the 2003 can?
_________________________________
Mike Walsh walsh@i...
Nope, there is no such animal - remember the current carrying capacity has a
lot to do with the power (heat) dissipation of the 16 DIP package.
If you are not using all 7 darlington transistors, you can parallel them for
higher current .
Or, you can hand build an plug in array using Zetex ZTX605's or similar.
Go read Scott Edward's Stamp Application #6 titles "Silicon Steroids for the
Stamp Help Your Projects Heft Big Loads". You can find it and other great
applications at: http://www.nutsvolts.com/stmpindx.htm
If you want to give up the "pin-for-pin" need, Toshiba makes a four channel
darlington driver good for 1.5 amps., in a 16 DIP. The TD62064AP (sink), get
it from Digikey $1.47.
Jim Howard
> From: agarb@j...
> Reply To: basicstamps@egroups.com
> Sent: Wednesday, January 17, 2001 5:52 pm
> Subject: [noparse][[/noparse]basicstamps] OT: uln 2003
Well, the company I work for (before I started) had a guy design a
product for us that uses the ULN 2003. I've recently inherited some
projects dealing with this device and have determined that the ULN 2003
is being used in a manner not in harmony with the TI datasheet --
basically, we are trying to pull as many as three outputs to ground
simultaneously. The scary part is that each device draws nearly 400 mA.
This = BAD. Instead of trying to cram buffer relays into an already
crowded enclosure, I was hoping to find a suitable replacement driver,
but have not even come close. Oh well, I guess I'll be going for the
buffers.
On Thu, 18 Jan 2001 12:20:29 EST Newzed@a... writes:
> If you need more than 500ma why not use a pc relay?
> Sid
If you only have to sink current, what about about a logic level MOSFET like
the IRL530? This device is in a TO220 case, can sink up to 15 amps, and
operates from a 5 volt logic signal. If the load is inductive, you will
need a catch diode.
Ray McArthur
To: <basicstamps@egroups.com>
Sent: Friday, January 19, 2001 7:04 PM
Subject: Re: [noparse][[/noparse]basicstamps] OT: uln 2003
> buffers.
> > Sid
just a thought,
back in the days when computers were steam powered we had a trick of adding
more memory by piggybacking extra chips on top of one another.
could this method be used to beef up the 300ma limit of the 2003.
ian.
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Saturday, January 20, 2001 2:17 PM
>buffers.
>> Sid
Ray:
I'm using this hexfet as a motor controller.....shou I have a diode across
the motor? motor draws 10 amps on startup.
Steve Chlupsa
SMC Enterprises
270-522-9376
Sent: Friday, January 19, 2001 8:10 PM
like
> need a catch diode.
> Ray McArthur
> From: <agarb@j...>
> > buffers.
> > > Sid
Yes ... the motor is an inductive load. The diode should have a voltage
rating > Vcc and current rating > max motor current.
Ray McArthur
Sent: Sunday, January 21, 2001 12:48 PM
> Ray:
> Steve Chlupsa
> SMC Enterprises
> 270-522-9376
> From: Ray McArthur <rjmca@u...>
> like
> > need a catch diode.
Sid
good luck,
Mike Walsh
walsh@i...
higher current .
applications at:
Jim Howard
> From: agarb@j...
buffers.
> Sid
need a catch diode.
Ray McArthur
> buffers.
> > Sid
ian.
>buffers.
>> Sid
Steve Chlupsa
SMC Enterprises
270-522-9376
like
> need a catch diode.
> Ray McArthur
> From: <agarb@j...>
> > buffers.
> > > Sid
Ray McArthur
> Ray:
> Steve Chlupsa
> SMC Enterprises
> 270-522-9376
> like
> > need a catch diode.
