Prgramming pbasic
>>>I am new to pbasic. I am tring to turn a compressor off past the
compressors turn off point. The compressor max is 125psi and the turn
off is set to 100psi. The pneumatics manual said if you want to go
past the 100psi, say to 110psi that you should use the program cycle
count to keep the compressor on for a longer period of time. This
will prevent the compressor from turning on and off continually.
How do you get the program count on a stamp bs2sx??
Bill Smitt
Bill Smitt
