subzero temp monitoring
Hi Fellow Stampers...
I have an older chest freezer (I'm guessing about 25 years old) whose
reliability I am starting to question. Since I have a great deal of food
stored in it, I am trying to come up with a way to monitor it so that it
don't go out on me and everything spoil without my knowing it. It would
be relatively to hook up a thermistor and use the RCTIME instruction, or
a DS1620, or ADC with an LM34. It would also be easy to do some type of
temperature readout on 7 segment display (somewhere, I think I have a
couple of sample MAX7219's sitting around) and sound a buzzer or flash a
light if the temp exceeds some setpoint. The problem with all this is I
have to run some sort of umbilical cord into the freezer and I can't
think of any elegant way to do this without compromising the rubber seal
and visual appearance. What would be really nice is some sort of
wireless method. Is this possible? The temperature in the freezer is
set to stay around zero -- how would this affect the reliability of
electronic components and battery life? Could some type of wireless link
penetrate the metal 'shell' around the freezer? If the answers to these
questions pose no problems, would I be better off to purchase something
already on the market (if such an item exists)? From Rat Shack, perhaps?
Aaron
Aaron
> Thanks,
> Aaron
might set off an inside audio alarm when the temperature falls below
freezing, but may require some research on electronic-device characteristics
related to temperature. Good luck.
I was testing a thermistor with the basic stamp and a wireless link.· I found that if I put the unit in my refigerator that the wireless transmitter could not penetrate the metal shell of the fridge.· Almost all of the wireless units are such low power that they have little chance of getting a signal through an enclosed box of metal.· Also, I tried it in the freezer portion of my fridge, and the 9V battery while in the freeqer would start dropping it's voltage and after a couple of hours, it didn't run the stamp anymore.· Once it thawed the battery worked OK again.· I think you would have to run a wire.· It might be possible to use one of those X-10 type signal and send the signal over the AC power lines.· If your freezer has a light inside of it, this would give you a place to attach to and also to get power from.· You would just have to disable the light switch so that the light was on all the time.
From: agarb@juno.com [noparse]/noparse][url=mailto:agarb@juno.com]mailto:agarb@juno.com[/url
Sent: Tuesday, January 16, 2001 5:37 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] subzero temp monitoring
reliability I am starting to question.· Since I have a great deal of food
don't go out on me and everything spoil without my knowing it.· It would
a DS1620, or ADC with an LM34.· It would also be easy to do some type of
temperature readout on 7 segment· display (somewhere, I think I have a
light if the temp exceeds some setpoint.· The problem with all this is I
and visual appearance.· What would be really nice is some sort of
wireless method.· Is this possible?· The temperature in the freezer is
electronic components and battery life?· Could some type of wireless link
penetrate the metal 'shell' around the freezer?· If the answers to these
Aaron
A non-wireless idea. If you have access to the inner liner from the outside
(perhaps through the compressor area), you could put your temp sensor on the
insulation side of the inner shell.
Daniel McGlothin
From: agarb@j... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XTf-QiCWAIEPH04caXCaOQSVjnC_0lQgDGvUzVGZe1pO5Y2TGWEqT3W68q6ZBp2H_D36691F1w]agarb@j...[/url
Sent: Tuesday, January 16, 2001 8:37 PM
Aaron
project you can do yourself, regardless of whether someone's already done
it. <g>
-- Mitch
From: LarryGaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=znCQyE5uhUWl2-UJZDvnbomqXv79qyMrug7qUhAR75jiXveyqpuUKQpJKMxlX-rRlfMCFL4cVWZTChkV]lgaminde@t...[/url
Sent: Wednesday, January 17, 2001 9:16 AM
Subject: Re: [noparse][[/noparse]basicstamps] subzero temp monitoring
Freezer alarms are about 25 bucks ( buy one )
> Thanks,
> Aaron
can spend four times as much in parts not even considering the opportunity
cost of your labor? This kind of project defines the original meaning of the
word "hack": to re-purpose object in way that creates a whole greater than
the sum of the parts that is at once elegant yet unecessary. That was before
journalists used the new derogatory meaning of hack as defining the unlawful
and destructive breaking into networked systems.
Right on and big Tim-Taylor Tool-Time grunt Aaron.
From: LarryGaminde [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MZ6mVDXjOdz475-lMvT5HwQld0IpKx1o4ugoGBg4f6GjPeH0hw9pKfMsJVRDviv8LGzH59OpCipUSqirnm-k]lgaminde@t...[/url
Sent: Wednesday, January 17, 2001 7:16 AM
> Thanks,
> Aaron
switch will go, and tell you that it's not cold enough..
seeing as it should never happen, you wouldn't have to keep setting it
up..
Jason Lavoie
> Thanks,
> Aaron
> would give you a place to attach to and also to get power from. You
> all the time.
careful.. you'd be amazed how much heat a lightbulb can produce..
Jason Lavoie
out a turkey you can order one and have it delivered. Don't forget
to get a web address so you can check the temperature from the
office. We all know that it's coming to that so it looks like you
can get a jumo on it. GO FOR IT !! [noparse]:)[/noparse]
Dave
--- In basicstamps@egroups.com, "Mitchell D. Miller" <mdmiller2@h...>
wrote:
> Larry, You're just TOO practical. There's nothing like throwing
$100 at a
already done
> it. <g>
> -- Mitch
> From: LarryGaminde [noparse][[/noparse]mailto:lgaminde@t...]
whose
of food
that it
It would
instruction, or
type of
have a
flash a
this is I
can't
rubber seal
freezer is
of
wireless link
to these
something
perhaps?
> > Thanks,
> > Aaron
In regard to the freezer, I worked for an appliance repair shop at
one time, and one method we used to monitor the refrigeration cycle
of a freezer was to route our wires through the drain line found at
the bottom. This saves the headache of wireless transmission as well
as door sealing.
Many older refrigerators have a small drain hole in the bottom that
connects to the drip pan underneath. Some freezers have this too.
It would be a relatively simple matter to route your sensor or 9 volt
power wires through this hose (if it is there). The drain hole is
sometimes hidden behind a false-panel, frost, or behind/under the
drawers, so if you don't see it it doesn't mean it isn't there.
Sometimes they are plugged with cotton or other water-permeable
materials to prevent heat loss; don't be afraid to poke that stuff
aside.
A rule of thumb - if you have a drip pan (visible as a yellowish pan
underneath the condensor coils on the bottom of the fridge/freezer),
you probably have a drain hole.
whose
of food
that it
would
instruction, or
type of
have a
flash a
is I
seal
is
wireless link
these
something
perhaps?
> Thanks,
> Aaron
without any freezer fault. craig
On Wed, 17 Jan 2001 17:08:00 -0500 Jason Lavoie
<jlavoie@e...> writes:
> just hang a block of ice from a micro switch.. if the ice melts, the
> it
> up..
> Jason Lavoie
> whose
> of food
> that it
> would
> instruction, or
> type of
> have a
> flash a
> this is I
> can't
> rubber seal
> freezer is
> of
> wireless link
> these
> something
> perhaps?
> > Thanks,
> > Aaron
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
ability to preserve food. The temp needs to be around 0 to -10 F to keep
most foods from going bad. I had a freezer that I thought was working fine
until I took some food out after a few months and found that it had spoiled.
Even though the freezer was still icy and frosty inside, the temp was in the
20's.
Pat
> except for sublimation (spelling?) which will cause the ice to go away
> > it
> > up..
> > Jason Lavoie
> > whose
> > of food
> > that it
> > would
> > instruction, or
> > type of
> > have a
> > flash a
> > this is I
> > can't
> > rubber seal
> > freezer is
> > of
> > wireless link
> > these
> > something
> > perhaps?
> > > Thanks,
> > > Aaron
X-Mailer: Juno 1.49
X-Juno-Line-Breaks: 0-23
X-Status: Unsent
A popular topic... if you want something that melts
at a lower temperature than water to close some
contacts try salted water adjusted to work - and
I'd suggest a magnet and reed switch instead of
micro switch.
I made a freezer alarm using a $20. module which
ran on 1.5v with LCD had max/min alarm outputs and
readings... Radio Shack - of course they discontinued
it :-( . In practice it was used in a chest freezer
with skinny wires going by the seal gasket... of course
that's where the rodents tried to get in and chewed
through the thermistor sense wires :-( .
Bimetal strips can work at these temperatures - the
problem being keeping the contacts clean.
Good luck with the project... for a simple alarm
with hysteresis it can be done with a thermistor
and op amp and some resistors and a piezo buzzer.
premena
As for running wires through the door of a freezer:
How about thin strips of tinfoil, used just where you transfer from the
inside to the outside of the freezer?
Would be fragile, but perhaps a bit of packaging tape over them would do
the trick. These "wires" would probably still allow a very good seal as
they are so thin.
Have a nice evening,
Paul
> premena
From: Paul J. Csonka [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=y3IgqerGIf2BCc92g2liKat7HD7INFxu_F3EjPDqUOChsqWlnUE6GbEJ_8BdcGCeE1rEJF1N-ZY]csonka@e...[/url
Sent: Thursday, January 18, 2001 5:57 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: subzero temp monitoring
To whoever started this thread (I'm sorry I don't remember).
they are so thin.
Paul - A commercially available version of this idea are flat speaker
cables, designed to be fastened to a wall and then painted the wall color.
Dennis
used for wiring electricity into doll houses. It is the thinnest wire I
have seen and it has a sticky side for sticking it to the freezer. You can
get it at most hobby shops, or craft stores.
> From: Dennis P. O'Leary [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=P4cxuz39FKaj7umD2AxzqIjSPKw_N9SHc5ihAsHPm7hRFujtl3jNNWhp4AffqsQB6TT2fLlGloTG6A]doleary@h...[/url
> Sent: Friday, January 19, 2001 12:01 AM
> Subject: RE: [noparse][[/noparse]basicstamps] Re: subzero temp monitoring
> From: Paul J. Csonka [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DlIW5PvRrWZIgzYzdjgspxeCso1loPh5p4drtUnc3ImMSaetoyPI5UvahOt1jbAO6iC28WiH]csonka@e...[/url
> they are so thin.
> Dennis
to my earlier question about monitoring the temperature in my freezer. I
think I am going to look for a commercial unit first -- after all, my
time's worth something. If that don't pan out, I will bear in mind the
suggestions to find a drain line or use flat speaker wire or flat
"doll-house" wire to get my signals into the freezer. Thanks again. --
Aaron
